Ignitin coil moisture? - Club Touareg Forums
post #1 of 15 Old 12-18-2013 Thread Starter
Have an 04 v6. Te car is having some misfiring problems. The service liaison is telling me that the coils were poorly designed and don't allow moisture to escape. He said replacing the coils is necessary to prevent future misfire problems.
Has anyone heard if this type of problem?
KirkLK is offline
post #2 of 15 Old 12-18-2013
There has been an ignition coil recall. Was your car included? My 2003 was.
post #3 of 15 Old 12-20-2013
Baltimore Touareg's Avatar
Did they replace your spark plugs at the time of the recall repair as part of the recall or no?
Baltimore Touareg is offline
post #4 of 15 Old 12-21-2013
No.
post #5 of 15 Old 12-22-2013 Thread Starter
Problem was resolved with new coils and spark plugs.
KirkLK is offline
post #6 of 15 Old 12-22-2013
Glad you got sorted.
Thanks for coming back and letting us know - lots of people don't!
post #7 of 15 Old 10-15-2016
Touareg: 2003 V6
Sorry for bumping an old thread here chaps. But this seems to be an ongoing problem for me.
Plugs have been replaced, as have the coils. Yet with just over 1000km since the coil plugs were checked, my misfire returned.
I pulled the coils today and found thus...
https://www.clubtouareg.com/forums/at...161242&thumb=1
this was the worst one, but all coils had some amount of water and corrosion in them.
what's the dealio here? could this be coolant? it had a brownish tinge to it, but i thought maybe it was just water and the corrosion caused the discolouration?
if not, how the heck is water getting in? i haven't sprayed the engine or driven through any water deeper than a couple of inches.
background is i have had the car for about 10k, and the misfire caused by this issue is now a third time deal.
in addition, i've had the rear brake light warning for a while now and one of the globes was dead. i've since replaced both and all working including the led strip thing on top of the tailgate - still got the dang message on the display. the "joys" of an 04 egg i guess. getting rather sick of troubleshooting rather than driving the thing.
Dan_p is offline
post #8 of 15 Old 10-15-2016
How does the rubber seal look on the plug? The part that plugs into the coil from the wiring harness. There should be no water inside the plug cavity like that.
If all else fails, smear some die-electric grease in there to protect the contacts and possibly seal the faulty plug seal.
post #9 of 15 Old 10-23-2016
Touareg: 2003 V6
I suspect you're right - i believe the water is getting in through the plug that the wiring goes into (no idea what this part is called) and then making its way down to the coil connector, corroding along the way.
I wonder if I can replace those plugs or if I'd need to replace the whole wiring loom?
Just guessing now - but the drain plug above the firewall was quite gunked up with debris. I'm wonder if in heavy rain it pools in there and then sloshes around as the car bumps around?
Other than that I'll see what I can do to make the existing plugs watertight...
Dan_p is offline
post #10 of 15 Old 10-23-2016
The plug on the wiring harness side should also be sealed. You could probably replace the connector on the harness side, but the tools to do it would be kinda $$ for a one time deal. :- /
Another option would be to find a used harness and splice in a known good connector. Probably not an ideal option, though.
