Hot start detonation - Club Touareg Forums
post #1 of 15 Old 07-25-2018 Thread Starter
2008 V8 FSI
When the engine is at operating temperature, shut down for 1-5 minutes, and restarted, I get detonation about 50% of the time. It's only one or (rarely) two pings, and does not seem to happen again while running. Cold starts are always fine. I only run premium fuel.
Does anyone else have this? What about in Q7s of the same age?
hydrolocked is offline
post #2 of 15 Old 07-25-2018 Thread Starter
I should mention: no codes in VCDS, MIL, or otherwise any indication anything is wrong.
post #3 of 15 Old 07-29-2018 Thread Starter
Update: "Top tier" seems to mean nothing for my particular problem. Octane booster, though, has stopped this from happening. I used 104+ by Heet. Will update again once I can test with a full tank of ethanol-free without additives.
post #4 of 15 Old 07-29-2018
FSI is bad for carbon buildup. Look for some of the de-carbon threads for more info.
nickyt is online now
post #5 of 15 Old 07-29-2018 Thread Starter
Thanks, but it was carbon cleaned less than 10k miles ago, and when it was gunked up it had no symptoms at all. I'm starting to suspect the cleaning has caused it, somehow...
EDIT: I spoke too soon. The octane booster has not solved the problem. Back to the drawing board.
post #6 of 15 Old 07-29-2018
mtnride's Avatar
Touareg: 2007 V8
Second Vehicle: 2007 V8
Coil packs, plugs? Possibly oil in spark plug tubes. This happened to both our FSI's. I replaced both engine's valve cover gaskets and made sure mating surfaces were super clean and everything tightened to specs and still had oil in tubes with spark plugs and coils soaked with oil. Off with valve covers again and used RTV to seal the gaskets when I put it back together.
mtnride is offline
post #7 of 15 Old 07-29-2018
^^Truth in the above. Pull the coils and plugs and look for any tell tell signs.
The valve cover gaskets are prone to leaks in both versions of the V8 engine. The internal o-ring type gaskets (that seal the spark plugs) often go bad as mtnride described.
post #8 of 15 Old 07-30-2018 Thread Starter
Thanks for the lead, folks. I'll check it out
post #9 of 15 Old 08-02-2018 Thread Starter
No go. Pulled the coilpacks and there's not a trace of any oil in the spark tubes. While I'm glad my valve covers aren't leaking, detonation can cause much more expensive damage, so it's a bummer that wasn't the answer.
mtnride mentioned the coilpacks specifically. There are painted dots on some of mine from the previous owner. I think I know what that means. Can faulty coilpacks cause knocking?
Hoping to hear other suggestions. Thanks
post #10 of 15 Old 08-05-2018 Thread Starter
Ethanol free fuel did not help me here. Still looking for an answer. I'm due for a spark plug changed based on mileage, so will see if there is any improvement.
