HIGH IDLE - Club Touareg Forums
post #1 of 9 Old 09-20-2014 Thread Starter
Greenguy's Avatar
Touareg: 2015 V6 FSI
HIGH IDLE
I have a 2008 Volkswagen Touareg, with 93k miles. When the vehicle has been parked for a while, upon start-up, the idle is very high. After about a minute, it kicks down. When I purchased the vehicle, it had 87k, and it never did this. Why now?
Greenguy is offline
post #2 of 9 Old 09-20-2014
You sure it's not the truck building up oil pressure?
It's Normal for it to idle above 1000rpm for about a minute. If it hasn't been driven in awhile, all the oil is in bottom of the oil pan. The engine goes into "bypass" mode in which it skips the oil filter so oil can reach the engine internals faster. This usually raises the engine rpm. Don't ever drive until it goes back down below 1k. It normally happens in mornings or again if it hasn't been driven in awhile. U usually won't see/feel it after u have driven once in the day.
If it idles high more than once. ie like after a stop light/sign; than get it scanned or u have another problem
wellsZe is offline
post #3 of 9 Old 09-20-2014 Thread Starter
Greenguy's Avatar
Like you said. It only happens in the morning, and if it hasn't been driven for a while. No problems at stoplights.
Greenguy is offline
post #4 of 9 Old 09-20-2014
4ePikanini's Avatar
Touareg: 2005 R5 TDI
Also check battery. It ups the idle when power is short to help the alternator provide some power.
I have had that once or twice when doing stuff inside the car with radio and lights on but engine off. The next start was a tad lazy and for a minute or two the revs were high.
2001 Gen3 Di-D LWB - SOLD
4ePikanini is offline
post #5 of 9 Old 09-21-2014
ColumbusTouareg's Avatar
My 2008 v8 has done it every morning also. Revs high for about 30 seconds then goes down. My battery shows 14v and has always done it since I bought it used. Assumed it was normal and warming up.
2008 4.2L FSI, Alaska Grey with Teak interior, Air Suspension, Added rear heated seats, Heated Steering Wheel, RNS510 Retrofit, Rear view camera and parking sensors, Adaptive Cruiser Control with Front Assist Retrofit, Side Assist/Lane Change Retrofit, OEM Tow package, 35% Llumar matching tint, 20" Carrera Wheels, 275/45/20XL tires. VAG Com by Ross-Tech, Yellow Porsche F/R Sway Bars, R50 front valance
ColumbusTouareg is offline
post #6 of 9 Old 09-21-2014
Perry01's Avatar
Mine does it too after sitting overnight. It's normal.
2016 AUDI A3 S-LINE
2015 Q5 PREMIUM PLUS
Perry01 is offline
post #7 of 9 Old 09-21-2014
Pierce330's Avatar
Touareg: 2009 V8
Normal...until the secondary air pump turns off...If I am understanding the surge in idle upon cold start up...my 4.2 does it every morning...
Pierce330 is offline
post #8 of 9 Old 09-21-2014 Thread Starter
Greenguy's Avatar
Ok. What about when I leave work, and the temperature outside is 70 degrees. I think when I take it the dealership, for maintenance, I will have them address this. It just seems odd, that when I bought it with 87k on the vehicle, no high idle right after start-up. But now, with 93k, a change in idle.
Greenguy is offline
post #9 of 9 Old 09-22-2014
Pierce330's Avatar
Touareg: 2009 V8
If the vehicle sits in one spot for a long period of time or one whole work day, it usually requires about 30 seconds for the seconday air to turn off...almost like turning it on in the morning
