HELP....1st post and heaps of codes!!! - Club Touareg Forums
post #1 of 10 Old 10-31-2014 Thread Starter
Hi there
I have a 2005 3.2 v6 Touareg which has been running rough lately. A friend downloaded the codes and I would appreciate if anyone could assist.
VCDS-Lite Version: Release 1.2
Friday, 31 October 2014, 20:46:54:8022
Control Module Part Number: 022 906 032 GA
Component and/or Version: MOTRONIC ME7.1.1G 6384
Software Coding: 0000133
Work Shop Code: WSC 31414
VCID: 50D3EC1583FB
16 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 001 - Upper Limit Exceeded - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 001 - Upper Limit Exceeded - Intermittent
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G2: Incor. Correl.
P1347 - 002 - Lower Limit Exceeded - Intermittent
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 008 - Implausible Signal - Intermittent
18619 - Bank 1; System too Lean at Idle
P2187 - 001 - Upper Limit Exceeded
18621 - Bank 2; System too Lean at Idle
P2189 - 001 - Upper Limit Exceeded
16686 - Cylinder 2: Misfire Detected
P0302 - 001 - Upper Limit Exceeded - Intermittent
16485 - Mass Air Flow Sensor (G70): Implausible Signal
P0101 - 008 - Implausible Signal
16452 - MAP/MAF <-> Throttle Position Correlation
P0068 - 002 - Lower Limit Exceeded
16689 - Cylinder 5: Misfire Detected
P0305 - 002 - Lower Limit Exceeded - Intermittent
16690 - Cylinder 6: Misfire Detected
P0306 - 001 - Upper Limit Exceeded - Intermittent
18679 - Oxygen (Lambda) Sensor B2 S1: Reference Voltage Open Circuit
P2247 - 004 - No Signal/Communication - Intermittent
16717 - Knock Sensor 2 (G66): Signal too High
P0333 - 001 - Upper Limit Exceeded - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 001 - Upper Limit Exceeded - Intermittent
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G2: Incor. Correlation
P1340 - 002 - Lower Limit Exceeded - Intermittent
Friday, 31 October 2014, 20:55:27:8022
Control Module Part Number: 09D 927 750 BN
Component and/or Version: AL 750 6A 0555
Software Coding: 0004136
VCID: 7B896BB97AFD
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Any help would be much appreciated. Thanks!
Azmatron
azmatron is offline
post #2 of 10 Old 10-31-2014
so I presume the first scan was done then faults cleared and only those 2 remained?
lots of faults for a rough running treg, first check of battery under seat.
Remove and test with carbon pile tester then advise
regards
Drag
dragline1570 is offline
post #3 of 10 Old 10-31-2014
post #4 of 10 Old 10-31-2014
Welcome to the forum Azmatron!
benb2376 is offline
post #5 of 10 Old 10-31-2014
2 different control modules here : engine and trans.
benb2376 is offline
post #6 of 10 Old 10-31-2014
miles
how many miles on her??
rooster777 is offline
post #7 of 10 Old 11-08-2014
G6mdxvct's Avatar
My bet based on error codes is elongated timing chain and possibly direct ignition coil issues. Bet if all codes are cleared the camshaft and crankshaft sensor errors will return. Chain issues are common on the V6, and it doesn't take a lot of mileage for the problem to appear.
G6mdxvct is offline
post #8 of 10 Old 11-08-2014
I don't think chain issues are common, but they are known!
post #9 of 10 Old 11-08-2014
Pierce330's Avatar
Touareg: 2009 V8
I would assume that your misfire issues are a result of bad plugs and coils...
Pierce330 is offline
post #10 of 10 Old 11-08-2014
G6mdxvct's Avatar
Agree, and not very expensive to replace. The camshaft/ speed sensor correlation could be a faulty sensor for bank 2 or a failing speed sensor. Both not very expensive to replace. If new sensors are installed and codes don't clear timing chain is generally the problem. Vr6 likes clean oil and chain tensioners are subject to not operate as well with dirty oil. Think pulling and cleaning the upper tensioner, priming should be standard when you change the oil.
G6mdxvct is offline
