Fuel consumption jumping between 3 and 76 MPG (2004 V8) Huh? - Club Touareg Forums
post #1 of 11 Old 05-02-2017 Thread Starter
Hi all,
Just yesterday I bought a 2004 Treg (V in amazing shape, with just 77,000 miles. I love it, and have plans for a number of tasteful mods/retrofits.
However, my gas mileage has been atrocious - worse than it should be. Today I found that one of my intake manifold link arms is broken, and I'll be ordering a replacement from Gruvenparts tomorrow. Plugs and air filter were just done. The problem is that my MFI is displaying a current consumption that constantly quickly jumps from about 3 MPG to 76 MPG (I wish!) and back down again. It seems to be doing this almost randomly, and does not coincide with my driving/throttle. Anyone heard of this? Is there some sensor that I should be checking? Or could the broken link arm alone account for this?
My Ross-Tech cable is in the mail, so I can't check codes at the moment.
Thanks for any help guys
Whim is offline
post #2 of 11 Old 05-03-2017
Can't help on the MPG.
The key item on an early V8 is the timing belt. Change at 80K or 5 years, whichever comes first.
If the belt breaks your engine is toast so unless you know for certain the belt, tensioner, water pump and thermostat have been changed on time, you've already got your first job!
post #3 of 11 Old 05-03-2017
Ionman's Avatar
Like Nooby, don't even bother to look at the MFD/MDI for the mileage. If you must, just switch over to the "Since Refuel" MDF display. MFD/MFI, based on my fuel tracking under my Excel file, has anywhere between 1% to 25% error for my 2004. It's unreliable. I do the MPG tallying from refueling. Of course, mine doesn't jump from 3 to 76. Just a suggestion: clean your MAF sensor to start, and I would be looking or wornout/bare spot on the wires within the engine bay. Bad ground tends to create oddball vehicle display. Then just for your own DIY-er mechanic intuition, probe around the car for possible mods that could have cause MFD oddness. VagCom may show you old codes that probably give you a hint on where to go.
As Nooby hits it on the nail, perform a full maintenance. If you are uncertain what the old owner(s) had done, do everything for safe measure.
Once the belt and connected critical components are done, toss in:
Power steering fluid flush
Transmission fluid and filter drain and change (the longest and simple job you can do...emphasizing on the long wait for the drain)
Differential fluid change (pair up with transmission fluid).
Check/replace brake pads and rotors (pair up with transmission & diff fluid job)
While the engine is warmed, do the coolant flush.
Brake fluid flush (do it at the same time with tranny & diff fluid jobs)
Check driveshaft center bearing while you're down below..what the hell..check everything for rots, cracks, rust build-up, and damages. If the old owners were like us, we love to take our vehicle off-roading, exploring the areas were we couldn't with other inferior SUVs.
Sorry to slam it all on you, but high mileage vehicle requires TLC; lots of TLC means long lasting driving pleasure.
- Leo
When life offers you a blessed world to explorer, why stay home and see the adventures through others' eyes.
Ionman is offline
post #4 of 11 Old 05-03-2017
The intake runner when it doesn't work it will use up more fuel. Also the arm is broken more than likely the intake manifold is Frozen the runners inside are Frozen. See if you can open and closed Runner manually by hand
raffiseto1 is offline
post #5 of 11 Old 05-03-2017
Yes. Lots of EXPENSIVE TLC! LOL!!
post #6 of 11 Old 05-03-2017 Thread Starter
Thanks for the advice guys. Iím happy to say that the truckís been well-maintained (timing belt/water pump done, regular oil/filter, various system flushes, etc.). That said, Iím gonna do all that stuff again. I do NOT want any differential or tranny issues.
My new VCDS cable should be here tomorrow. I have a Micro-CAN because I had a MK5 Jetta, but itís no good with the Treg. Looking forward to delving back into this truckís history.
MAF cleaning will happen tomorrow Ė thanks Ionman. Iíll also take a look at wiring in the engine bay. The sound/heat insulation matting under the hood has some suspicious damage (i.e., chew marks) . So it may be that some rodent made a dinner of some wire sheathing.
raffiseto1 I can turn the flap pivot with the broken arm fairly easily and smoothly. It turns with about as much force as it takes to turn a can opener. Iím hoping that the new arm (and cleaning up the valve) will improve things.
Any of you ever use products any intake manifold cleaning agents? Seafoam? Iíve heard mixed reviews about using that kinda stuff with FSI motors.
Whim is offline
post #7 of 11 Old 05-03-2017
Oregon TDI's Avatar
Are you viewing Since Refuel or Long Term / Extended MPG data? Sounds like you're displaying the "instantaneous" data which will jump around wildly.
In spite of everything, I still like Volkswagens.
Oregon TDI is offline
post #8 of 11 Old 05-03-2017 Thread Starter
Long term consumption is at around 7 MPG but it can go up to like 18 MPG within about a minute. Current consumption is what jumps around the most.
I'm happy to just calculate manually based on miles per tank, and I will. I just don't like having anything that isn't working properly. Seems to me like it would be a sensor issue.
I wouldn't be surprised if the dealership from which I bought the truck put crap gas in it, but I don't think that would confuse the MFI that much
Whim is offline
post #9 of 11 Old 05-03-2017 Thread Starter
And I do understand that current consumption will hit the ceiling when you hit the gas, but it should never get anywhere near the 70s
Whim is offline
post #10 of 11 Old 05-03-2017
Ionman's Avatar
Mix bag in this forum. I would use it on cars that practically has no option left before a full overhaul, or just too old with nothing left to try. If an expensive job is going to render your budget into a hair raising scream, why not give it a try.
- Leo
Ionman is offline
