Engine misfire - Club Touareg Forums
post #1 of 5 Old 02-02-2019 Thread Starter
Engine misfire
Hi,
I have a 05 Touareg, getting an engine misfire in cylinder 2, I replaced the spark plugs, moved the coils around to see if the problem followed the coil, problem persists in cylinder 2, any ideas from here? Thanks!!
JonSand is offline
post #2 of 5 Old 02-03-2019
Pull the new plug out and "read it"..... are you dealing with a rich or lean condition?
post #3 of 5 Old 02-04-2019 Thread Starter
Problem solved! I replaced the spark plugs and then shifted the coils around to see if the problem followed the coils, initially I thought it didn’t but I guess I didn’t run it long enough for all the faults to trigger. Took it for little drive and the rest registered, replaced coils in the 3 cylinders that were faulting and she’s all better!
JonSand is offline
post #4 of 5 Old 02-04-2019
VW coils are infamous for failures. At this point, I recommend replacing the coils and the spark plugs at the same time. It saves you the hassle of replacing bad coils later.
post #5 of 5 Old 02-05-2019
Back in the day when I used to drive VAG stuff with plugs, almost everyone was driving around with spare coils in the trunk..... it was just normal.
R5 TDI Oil in Coolant DavPer Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 79 04-15-2015 04:59 PM
Watch Miller win Baja 1000 1st Turbo-Diesel Entry irok General Maintenance & Repair 2 12-02-2008 09:27 AM
V10 engine codes differences CsTDI General Maintenance & Repair 3 11-10-2008 07:47 PM
3rd engine in a V10 TDI!!! hyperviking General Maintenance & Repair 14 10-26-2008 12:22 PM
