Coil pack caught fire - Club Touareg Forums
post #1 of 19 Old 02-05-2018 Thread Starter
jrsride2002's Avatar
Yup, just as the title states it.
Pictures tell the tale, for the most part.
I JUST finished doing an alternator swap. Fired up the motor to see if it was a successful swap. It was. It took about 30 seconds to smell the burning electrical components.
I was on the passenger side, front wheel, admiring my handy work. Then I got my first sent, of a problem. While I was dashing over to turn the engine off, I noticed a good size plum of white smoke coming from the driver side front wheel well. I cut the engine, pop the hood, and was in shock! Luckily, no actual flames.
I spent an hour trying to get the other half of the coil pack out of the cylinder... It's still stuck in there.
My options are limited, but that's my story of the day. Overall, I'm sure it was just a old pack. I have slowly been replacing all of the packs. Luckily, I already had the replacement on hand. But I still have to get the old one out, first.
~Junior
Sent from my SM-G360T1 using Tapatalk
jrsride2002 is offline
post #2 of 19 Old 02-06-2018 Thread Starter
Well, my connector looks great! That was a relief. It was a second thought, but worth the concern. Glad it worked out in my favor.
The other half of the plug is really in there. I have a pair of pliers, that I get a good bite with. But that beast just won't budge... Anyone have any ideas I can try? I need more leverage, but I'm not sure how to get it. I grab the lip of the coil stem (???), but all I can do is pull straight out. I'm just so limited.
TIA guys,
~ Junior
post #3 of 19 Old 02-08-2018
mtnride's Avatar
Touareg: 2007 V8
Second Vehicle: 2007 V8
Could you possibly drill a hole in the top and put in a screw to be able to use a nail puller/pry bar. Looks like a tough one Junior!
Maybe some glue to make screw solid, good luck.
mtnride is offline
post #4 of 19 Old 02-08-2018
Built4Sin's Avatar
That sounds like it would work! Just be careful to not use too much, it kind off looks like the spark plug head in the middle. Might have to use JB weld and set a sacrificial socket in there to bond only to the outer ring of material left.
mtnride likes this.
| Cayenne TT Sways |
Built4Sin is offline
post #5 of 19 Old 02-08-2018 Thread Starter
Thanks for the ideas guys!!
While I will try them out. Here's another question for you. What about removing the valve cover? Would that give me greater access, or more to work with?
post #6 of 19 Old 02-08-2018
mtnride's Avatar
Touareg: 2007 V8
Seems to me you have to remove coils and plugs to remove valve cover but Iíll check my Bentley Repair manual later and see what I can find
mtnride is offline
post #7 of 19 Old 02-08-2018
mtnride's Avatar
Touareg: 2007 V8
By looking at whatís left of the coil, I think there is some room. I would guess the top of the spark plug terminates a little above the black knobs
mtnride is offline
post #8 of 19 Old 02-08-2018
mtnride's Avatar
Touareg: 2007 V8
Junior, another thought, as above drill hole but use lug nut cap removal tool, insert in hole and pull. Worst case the top of fried coil separates coil stem. You could probably grab coil stem with needlenose pliers at that point.
Let us know how it goes.
mtnride is offline
post #9 of 19 Old 02-08-2018
Spiegelglatt's Avatar
Second Vehicle: 2007 V6
Likely there is melted plastic that is bonding to the surround. Can it be forcefully twisted counter clockwise (so as to not damage spark plug threads?) perhaps the socket idea mentioned above with fast drying epoxy and an extension in the socket...then a ratchet with a beaker bar.
Breaking the outer bond of the melted material is the key you need to accomplished. Pulling straight out at first is just going to give you a good workout.
Spiegelglatt is offline
post #10 of 19 Old 02-08-2018 Thread Starter
Iwas thinking the same, but was also thinking that if it doesn't work. Maybe the drill would be worth the effort. So I'll start with the drill, then try the socket.
DUDE! You're telling me!!
I might not be that strong, but I found myself in a advantageous position with the extra leverage from my keg belly on the quarter panel. And it's still not enough?! I did some digging, and if all else fails. It'll be a new head. Those spark plug tubes, are NOT removable. So getting the valve cover off, then trying to pry the junk out COULD damage the tube. Which means a new head. The valve cover, is keeping the tube stabilized from being bent in a undesirable manor.
So if anyone sees this issue again, KEEP THE VALVE COVER ON. Or suffer the possibility of replacing the head.
