3.2 V6 Timing belt failure (teared) - Club Touareg Forums
post #1 of 13 Old 05-06-2014 Thread Starter
davszabo12's Avatar
Dear All!
I have a Treg 2005 3.2 v6 with 135.000km. Last weekend we were on a holiday with friend (4 people, bikes on the roof) and my car accidentally stopped at the highway on light slope. First it was less of power for a few seconds after stopped the engine. After that I can't start anymore, only two turning from the starter but nothing from the engine.
Yesterday my mechanic looked in the upper part of the motor with a small camera, that is any moving in it when we try to start and try to make some round mechanically. No moving at the valves or the rods.
It seems, that the timing chain was teared. I can't find anybody on the forums who have the same problem.
There was no rattling or any other noise from the car. The speed was 100-120km/h.
If somebody have information problem like this, please let me know, because the local VW dealer also don't know any case like this.
Thank you
David
davszabo12 is offline
post #2 of 13 Old 05-06-2014
It is a known issue that the timing chain can stretch and rattle badly on a 3.2 which can require the engine to be pulled to replace it but I cannot recall reading about a complete failure.
post #3 of 13 Old 05-06-2014 Thread Starter
davszabo12's Avatar
There was no rattling, no noise. Not any notice before that this could happen. Actually the car was at the mechanic for supervise it before the trip and he said everything is fine.
I read some post about R32 Golf's that broke the timing chain, but I don't exactly know that the engine is the same!?
I think the biggest question is that the valves are broken or not...?
post #4 of 13 Old 05-06-2014
4ePikanini's Avatar
Touareg: 2005 R5 TDI
if the chain did indeed snap at 120km/h the engine is toast.
2001 Gen3 Di-D LWB - SOLD
4ePikanini is offline
post #5 of 13 Old 05-06-2014 Thread Starter
davszabo12's Avatar
The engine stopped immediately! First turned off the cruise control, then slowing and engine stopped.
There is no engine or any other light on the dash and there is no error code on the VAG computer.
post #6 of 13 Old 05-07-2014 Thread Starter
davszabo12's Avatar
post #7 of 13 Old 05-18-2014
I have never seen this, keep us posted any damage to the head?
Billlovesvag is offline
post #8 of 13 Old 05-18-2014 Thread Starter
davszabo12's Avatar
Dont know yet, we should remove the engine first. Thats the only way to see whats damaged.
post #9 of 13 Old 05-18-2014
2004 touareg 3.2v6 flywheel damage
I thought I had a timing chain issue also. My touareg felt like it had a loss of power then acted like the transmission went into neutral I turned the ignition off and it wouldn't turn back on. Had it towed to my mechanic they check battery, starter, and all electrical then tried to turn engine over and noticed the cams would not move they first thought the timing chain or gears came apart. They pulled the engine out and noticed the flywheel and flex plate broke it was an expensive repair about $1700.00 but at least no damage to engine. You might let your mechanic know about mine. Good luck
rlgarcia is offline
post #10 of 13 Old 05-18-2014
roalco's Avatar
That's going to be a big rebuild. It appears from the photo the timing chain separated (failed master link?), that will keep the valves in position, and on the cylinders that had valves open, the pistons will likely have impact damage, as well as bent/broken valves and possibly cylinder head damage. Hopefully no bent connecting rods, but they will have to be checked too.
Ouch!
2012 Touareg TDI ("Badger"), Highline with sport and towing pkg., Canyon Grey/Black. Awesome.
1984 Toyota Landcruiser BJ60 ("Huntley"), Blue/Brown, 3B diesel, manual everything, daily driver for the past 27 years and 454,000km. Priceless.
Dog is my co-pilot.
roalco is offline
