3.2 v6 location EVAP N80 - Club Touareg Forums
post #1 of 10 Old 06-15-2014 Thread Starter
Touareg: 2003 V6
Hi. I cant find purge valve (EVAP) N80. Have some pictures from vr6 study handbook but it looks diffrent than my engine. Does anyone know where is it?
PredatorPL is offline
post #2 of 10 Old 06-15-2014
Touareg: 2007 V6
DasDubVR6 is offline
post #3 of 10 Old 06-15-2014
Touareg: 2007 V6
Here is a video of it being replaced on a 2.8l VR6, I know it's not an answer but can help you get an idea. VWVortex.com - VR6 Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) - 720p How to DIY
post #4 of 10 Old 06-15-2014 Thread Starter
Touareg: 2003 V6
Thanks guys. I have read and watch all of that but its not my engine. Still looking for that part
post #5 of 10 Old 06-16-2014
Touareg: 2007 V6
No, but it gives you an idea of what to look for.
On my R32, if memory serves me right it's on the back of the engine by the throttle body.
Being longitudinally mounted that puts it on the passenger side.
post #6 of 10 Old 06-18-2014 Thread Starter
Touareg: 2003 V6
I meet my friend who also have treg but his come from U.S and he have some sticker next to engine area so tommorow i will look for it. Hope this is it.
post #7 of 10 Old 01-11-2018
Baltimore Touareg's Avatar
Bubbling this thread up the top as I am working on replacing parts in my engine bay.
I've discovered that the evap purge valve is located somewhere next to/under the engine air filter.
If I am successful finding it in my T1 v6, I'll post pics here of it's position.
Baltimore Touareg is offline
post #8 of 10 Old 11-30-2018
Were you able to locate the part? I'm having the same issue with my 2007 Touareg, and can't locate the Purge valve.
barfed64 is offline
post #9 of 10 Old 12-01-2018
post #10 of 10 Old 3 Weeks Ago
jsrmonster's Avatar
Hi The n80 evap solenoid is at the rear of the engine, not in the RR wheel well. Remove the intake pipe and reach back to find sensor and pull out toward the passenger side for access. Disconnect the 2 wire connector and you'll see the fault for missing n80 so you know it's correct sensor. You'll need small pliers to slide back the spring clamps, and need to pry off the hose, it seems glued on. Be careful of small 1/8" plastic vacuum pipes near by, since they break easy if you crank on them too much. Install new sensor PN#1C0906517A, and clear fault codes. Obviously, check all 1/2" plastic vaccum pipes for leaks and tape-up or replace as desired. Jeff
jsrmonster is offline
