04 ecu replacement - Club Touareg Forums
post #1 of 17 Old 08-09-2015 Thread Starter
04 ecu replacement
Hi, my touareg needs a new ecu. Is it a matter of just replacing it or is this something only the dealer can do?
eruss is offline
post #2 of 17 Old 08-09-2015
How do you know it needs a new ECU?
post #3 of 17 Old 08-09-2015 Thread Starter
Dealership wanted to put a new one in because it wasn't responding.
Just spoke to a friend d who had the same issue and he's seems to remember it was something in the steering column he replaced.
eruss is offline
post #4 of 17 Old 08-09-2015
Yeah the ecu has to be coded and programmed to immoblizer, to program immobilizer vag scan tool has to talk to fazit in germany which is a secure server. There may be a way around this but I haven't heard of a way personally.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Dpkhym is offline
post #5 of 17 Old 08-10-2015
Exactly what happens when you try to start the car?
post #6 of 17 Old 08-10-2015 Thread Starter
The only thing that happens is the dash shows a red steering wheel sign. Other than that nothing.
eruss is offline
post #7 of 17 Old 08-10-2015 Thread Starter
Unfortunately it appears vw has me by the balls on this one.
eruss is offline
post #8 of 17 Old 08-10-2015
I hope others will perhaps chime in here, but there's something in the old grey matter that's saying duff yaw sensor or some-such, or possibly something to do with the brakes . . .
Or is it the clock spring fault in the steering wheel?
Something is nagging at me on this one . . .
post #9 of 17 Old 08-10-2015 Thread Starter
The research I have done suggests it starts with replacing the battery which was just done. From there it seems to be a problem from the key faub to the steering wheel to the ecu.
I suspect it's a faulty wire but it's easier for them to replace everything rather than hoping to find a bad wire.
eruss is offline
post #10 of 17 Old 08-10-2015
Now that just does not make any sense at all.
Think about it: if it is a bad wire somewhere then that bad wire will still be bad even with a new ECU.
It always helps if you give the complete background to a fault. Delivering it piecemeal doesn't help you or anybody trying to assist!!
Go back to the beginning and describe what, exactly, has happened - the whole sequence of events . . .
