The NEW VW RealDriver extended service contract - Page 19 - Club Touareg Forums
post #181 of 205 Old 10-24-2011
Was there a reply to the question about what extended warranty(ies) are available for a 2004 with approx. 62,000 miles? Thanks!
copaz is offline
post #182 of 205 Old 02-06-2012
Second Vehicle: 2006 V8
Chris, You have PM
yrktreg is offline
post #183 of 205 Old 02-12-2012
I have the Real Diver warranty, 04 V8 with 63k and dropped it off at the shop Thursday.... I'm a little afraid:
doors rattling,
sunroof clogged and leaking in car
valve throttle body
and water pump leaking..
I hope warranty covers it all...
Smileyboy is offline
post #184 of 205 Old 02-13-2012 Thread Starter
doors rattling,
valve throttle body
Warranty will cover water pump and valve throttle body, however, not real sure on the doors rattling and the sunroof leaking if it is maintenance issue w. the drain tubes!
Chris
13 year vet is offline
post #185 of 205 Old 02-15-2012
Chris PM sent
2004 V8, then 2005 V8, then 2008 V8, now 2015 TDI
suva is offline
post #186 of 205 Old 02-20-2012
Highly recommend dealing with Chris.
yrktreg is offline
post #187 of 205 Old 03-03-2012
BlazinPond's Avatar
Chris,
Incoming message regarding extended warranty for my new Treg!
Thanks!
2012 VW Touareg TDI Executive - retired
BlazinPond is offline
post #188 of 205 Old 03-10-2012 Thread Starter
New Revised rates as of Jan 01, 2012
Chris here from VW of Langhorne in Langhorne, PA.
The VW Drive Easy extended service contracts have changed as of Jan 01,2008
They have now combined the new car extension w/ the used car extension and
have come up w/ one main plan.
Now the time starts the day you sign up and the miles you choose are on top
of what you allready have!
They still have the same verbage in the new contract as far as coverages
that will be explained here:
> Allthough I am open to all coverages, I would reccomend the Platinum
> coverage as it is an exclusionary warranty vs an inclusiuonary warranty!
> These quotes are w/ a std $100 deductible.
> Should you want a $0 deductible, please add an additional $230-$517
> depending on the terms you choose!
The $100 std deductible is per visit, NOT per complaint!
> This extended service contract is valid at ANY VW dealer and the dealer
> gets
> paid thru their parts and warranty dept.
> This warranty is also valid at authorized shops and they get paid thru a
> credit card.
> You are never responsible for more then your deductible!
> If you cancel in the first 60 days, it is 100% refundable, after the 60
> days, it costs $50 and the plan will be pro-rated!
> To transfer the contract it costs $40!
> The warranties I sell are geuine VW warranties. I DO NOT deal in
> aftermarket
> warranty companies! The service contract is backed by VW and fascilitated
> thru Fidelity Warranty Services!
> Here are the coverages:
> The Gold covers:
> Engine
> Transmission
> Drive axel
> Steering
> Brakes
> A/C
> Front Suspension
> Electrical
> The Gold Plus covers all of Gold plus:
> Cooling System
> Fuel System
> A/C system
> Steering
> Front Suspension
> Rear suspension
> Electrical
> The Platinum covers all that and the rest of the entire car w/ the
> exception
> of this:
> brake linings,brake drums and rotors,disc brake pads,std trans clutch
> components,air bags,solar powered devices,hinges, glass, lenses,sealed
> beams,trim moldings,door handles, lock cylinders,tires, batteries, light
> bulbs,upholstery, paint,bright metal,freeze plugs,heater and radiator
> hoses,exhaust systems,shock absorbers,audio,security or other systems not
> factory installed, work such as front end alignment or wheel balancing,
> constant velocity joint boots, safety restraint systems,cellular
> phones,electronis transmitting devices{except those specifically listed
> under silver, gold, or gold plus coverage},radar detectors,appliances,near
> object avoidance systemand all oither laser radar cruise control
> components,
> vinyl and convertible tops.
Here are the quotes depending on how many miles are on your Touareg
Please note that this contract starts from the day you sign up and the
miles
are on top of what you allready havexxxx +
These quotes are vaild until you hit 9999 miles or the end of the year!
4yrs or 100K=$1247 + 6% pa tax
5yrs or 60K=$898 + 6% pa tax
5yrs or 75K=$1022 + 6% pa tax
5yrs or 100K=$1314 + 6% pa tax
6yrs or 60K=$930 + 6% pa tax
6yrs or 72K=$1084 + 6% pa tax
6yrs or 85K=$1159 + 6% pa tax
6yrs or 100K=$1537 + 6% pa tax
7yrs or 70K=$1141 + 6% pa tax
7yrs or 100K=$1675+ 6% PA TAX
10yrs or 10K=$2187 + 6% pa tax
These quotes are valid up to 24999 miles{note, you get an additional 15K, however, the price jumps dramatically!}
4yrs or 100K=$1962 + 6% pa tax
5yrs or 75K=$1687 + 6% pa tax
5yrs or 100K=$2402 + 6% pa tax
6yrs or 60K=$1450 + 6% pa tax
6yrs or 72K=$1762 + 6% pa tax
6yrs or 85K=$2013 + 6% pa tax
6yrs or 100K=$2816 + 6% pa tax
7yrs or 100K=$3031 + 6% pa tax
These quotes valid up to 34999 miles
3yrs or 36K=$1203 + 6% pa tax
4yrs or 48K=$1464 + 6% pa tax
4yrs or 60K=$1752 6% pa tax
5yrs or 60K=$1824 + 6% pa tax
5yrs or 75K=$2146 + 6% pa tax
6yrs or 60K=$1904 + 6% pa tax
6yrs or 72K=$2226 + 6% pa tax
These quotes valid up to 44999 miles
3yrs or 36K=$1728 +6% pa tax
4yrs or 48K=$2079 + 6% pa tax
4yrs or 60K=$2300 + 6% pa tax
5yrs or 60K=$2444 + 6% pa tax
6yrs or 60K=$2661 + 6% pa tax
6yrs or 72K=$3527 + 6% pa tax
post #189 of 205 Old 03-14-2012
PM Sent - Extend Warranty
Hi Chris, PM Sent to you... extending warranty for 2nd time.
frviana is offline
post #190 of 205 Old 03-14-2012
Official CT Ricer!
catalystgod's Avatar
Chris, need a quote on a 2006 V10 black with 61.5Kmiles. Currently under CPO until 69/70K miles (can't remember exactly).
catalystgod is offline
VW RealDriver extended service plans 13 year vet Commercial Posts 57 03-07-2008 04:23 PM
VW Extended Warranty [email protected] Australia & New Zealand 4 10-01-2007 08:38 PM
Extended Warranty wmreg General Maintenance & Repair 1 09-27-2007 07:21 AM
extended warrenty Igot1 Touareg Reviews 13 09-03-2006 04:30 AM
Extended Warranty Ewan Australia & New Zealand 0 06-26-2006 12:28 AM
