T3 VAG-COM mods - Page 6 - Club Touareg Forums
 5Likes
post #51 of 126 Old 08-22-2012
In Australia we are KPH. But I also woudl liek KPH on both displays, seems to be KPH on teh big display and MPH on teh small
Ocean TV is offline
post #52 of 126 Old 08-22-2012
Touareg: 2011 V6 TDI
Originally Posted by Touareg1984 View Post
Any idea Kleinbus?
I think Kleinbus is busy deciphering the LED tail lights code.
Xam-D is offline
post #53 of 126 Old 08-22-2012
swampg8rs's Avatar
Originally Posted by IntProst View Post
I presume that the display is always the opposite of the MFD setting. My car is set for km/h on the MFD so the alternate display is in mph. Perhaps there is a way to change this using the VAG-COM, but it does not make sense that the manufacturer would make this a standard feature.
incorrect. I can change the MFD by changing the settings from MPH to km/h, but the alt display always stays km/h.
swampg8rs is offline
post #54 of 126 Old 08-25-2012
Zed1963's Avatar
i'ved tried several options with vcds - no way to change the alternative speed into the same stand as the big one.
It was me who asked kleinbus
this feature is very cryptic. If someone could find out - let us know pls
Zed1963 is offline
post #55 of 126 Old 08-25-2012
Second Vehicle: 2012 V6 TDI
Originally Posted by swampg8rs View Post
I have a US T3. I want mph on the Alternate Display, but all I can get is km/h no matter what language I set the system to. I suspect that his problem is the opposite. Why do I want this? It's so the I can have digital display at all time, no matter what other option is shown in the MFD. I'm sure its a VCDS setting, but I don't know what controller the change might even be in to compare settings.
If it's anything like my 2012 passat tdi, you want to go into Body Control Module on VAGCOM / VCDS, and then I am guessing you would have to go into Long Code Helper to find what you are looking for... keep using the left or right arrows to scroll left or right.
Niner is offline
post #56 of 126 Old 09-10-2012 Thread Starter
kleinbus's Avatar
Probably been posted on T1 and T2 threads but here it's again...
Video in motion
VIM login-code generator for MMI 3G
kleinbus is offline
post #57 of 126 Old 09-21-2012
Originally Posted by kleinbus View Post
I have 1568 on my 2012 and same coding is on another 2012 TDI without any issues so as you said, it have to have something to do with the different controller.
Anyways, thank you being first one with different controller to test and speaking out about the error...
I've had mine coded 1568 for the last 13k miles. No issues at all...no fault codes in VAG either. VAG part number for controller same as in the posted JPG.
pajohn is offline
post #58 of 126 Old 09-24-2012
SamTrooper's Avatar
Same
SamTrooper is offline
post #59 of 126 Old 09-24-2012
May 2012 build, TDI. Different controller, and for the gear display, 001568 showed high oil pressure also in the display ,as well as a warning and a check engine light as soon as I went in reverse.
001168 showed gears in Drive display also, and appeared to modify my shift points slightly also, seemed to hit harder on the shifts and the drive train, taking away the normal smoothness on the shifts. This was with the 30 second floor the throttle pedal "relearn" application applied both times.
I ended up putting mine back to the stock setting of 001368 after playing with this mod. Car now shifts great again, in the meat of the torque band, right where I like it.
YMMV, something in the later build 2012 tdi's has a newer version of a module, that I believe now ends in the number "3" versus earlier versions ended in "0"
Niner is offline
post #60 of 126 Old 09-24-2012
Same
slambam is offline
Other vag com mods Laggyband Australia & New Zealand 4 12-30-2011 02:40 PM
VAG COM Mods in NJ 4ringking VAG-COM 4 08-09-2010 08:17 PM
VAG mods for a 08 Treg? V-DUB Touareg Exterior Mods 4 01-23-2008 06:30 PM
Few Mods..... whitey General Maintenance & Repair 0 01-03-2007 07:51 AM
Mods?? GreekV8 Touareg Exterior Mods 2 05-21-2006 01:18 PM
