Summary of VAG-COM tweaks for the Touareg (T3)(7P) - Club Touareg Forums
 10Likes
post #1 of 54 Old 03-18-2019 Thread Starter
I know this has been a thought by many, but nothing was created. Now we can start a repository for all things VAG-COM for the 7P Touareg. Searching is always an option, but having a central location to find the most pertinent information would be helpful to everyone.
Going off of Noobytoogy’s Signature:
Seat Belt Warning Disable
[Select]
[17-Instruments]
[Coding]
[Long Coding Helper]
One of the drop-downs for Byte 00, you should have options, one of which should be:
"Seat Belt Warning inactive"
*Remember to always write down or take a picture prior to making even then simplest changes.
Other Points of Reference:
Ross-Tech Wiki
T1 - https://www.clubtouareg.com/forums/f...7-a-22216.html
T2 - https://www.clubtouareg.com/forums/f...9-a-22432.html
trdltly is offline
The Following 3 Users Say Thank You to trdltly For This Useful Post:
iSagen (04-01-2019), jagneauxm (3 Days Ago), topline (03-19-2019)
post #2 of 54 Old 03-18-2019 Thread Starter
  • RNS-850 hidden (Green) menu activation - Module 5F, 10 Adaptation, Channel 6, set 1 instead of 0. then press SETUP + CAR for several seconds.
  • Bluetooth activation
  • Webasto (in fact it is Eberspacher) activation (if physically installed)
  • Video in motion activation - Module 5F - Adaptation - Channel 6 - to 1. Then follow the instruction.
  • DynAudio sound profile activation
  • Enabling RNS-850 menu to control LED DRL
  • Service Interval resetting, change of Time-dependent, Mileage-dependent inspection intervals
  • Bypassing speed limit to access CAR settings menu - Module 5F - 10 Adaptation - Channel 2 - default is 15, set it to 100 if you want to setup it while driving
  • Disable indicators arrows test when turning on ignition
  • Change of headlights washers work algorithm
  • Disable rear wiper when put in (engaging) R gear
  • Enable sound confirmation when securing/unlocking the car (if immobilizer installed)
  • Enable Emergency Braking flashings
  • Coming Home/Leaving Home activation and control via RNS-850
  • Cornering Lights control, etc.
  • Add oil temperature indication to MFD - Module 17 (instruments), 10-Adaptation, oil temperature - active
  • Control of Klimaanlage and heated seats parameters
  • Enabling Off-road navigation for Tregs without terrain-tech
  • Saving DVD content to built-in HDD
  • Right mirror tilting when reversing
  • Rain and light sensors setting
  • Air Suspension re-calibration
Reset RNS-850 - "5-finger Method" Simultaneously press - Phone + Climate + Nav + Traffic + Knob
Steve_L likes this.
trdltly is offline
The Following User Says Thank You to trdltly For This Useful Post:
iSagen (04-01-2019)
post #3 of 54 Old 03-19-2019
Touareg: 2013 V6 FSI
Thanks for starting this keep adding things to your post I see a list of mods but not how to do them.
Sent from my iPhone using Tapatalk Pro
Andrew149 is offline
post #4 of 54 Old 03-19-2019
Here are the ones I have saved:
Autohold:
First, swap in autohold switch into center console
Step 1. Hit start/stop without pressing the brake pedal, engine should not be running.
Step 2. Open up channel 03 for ABS
Step 3. Fire up the long coding helper, no security access needed.
Step 4. Select “Byte 16”
Step 5. Change the coding from “01110011” to “01110111” in the binary area, don't forget to hit "enter" on your keyboard, then Byte 16 should read “77”
Step 6. Save it
Step 7. Now your TC, ESP, and ABS lights on your dash will flash, don’t worry, turn off the car.
Step 8. Start your engine, the 3 lights should be gone.
Step 9. Foot on the brake, click on seatbelt, you should be able to enable Auto Hold now.
To call up the green parking light for autohold in instrument cluster:
Step 1. Ignition on ACC
Step 2. Module 53, security access 21673, long coding helper, Byte 2, change to 01 ROW.
Step 3. After the module accepts the new coding, wait 2 minutes, turn off the car, then restart.
For those trying to get Gear Display on a 2016 Touareg TDI with 'fix':
Ignition on, Engine off, doors closed and unlocked
02 Auto Trans
Coding 07
Long Coding Helper
Byte 1 (Second Box)
Change from 02 to 05, Binary 00000001 to 00000101
Transmission reset:
w/VCDS:
Click on transmission
basic settings 04
channel 001
press go
w/throttle pedal
Door closed
Press and hold accelerator to the floor for at least 10 seconds
Release pedal
Ignition off, remove key
Open then close door
Fix software version error:
1) 5F (Infotainment) module, Adaptations, channel: 'Confirmation of installation change'
2) Note your current coding
3) Start Windows calculator and set it to 'Programming mode' and select 'HEX' option
4) Calculation: (current coding) Xor C9D2
5) Change the adaptation channel to the new code (Don't be surprised if it changes back to the original coding, this is normal!)
6) VCDS main screen, 'Auto-Scan'
7) Check for fault codes on all modules and clear the DTCs
Note that VCDS displays your code in 'xx xx' format (small letters and a space character).
You have to remove the space before you calculate your new code.
When you enter your new (calculated) code, insert the space again and use lower cases.
EXAMPLE (don't use these values):
'1a 1a' (original coding of the adaptation channel)
1A1A Xor C9D2 equals D3C8
Enter it as 'd3 c8'
If your original code starts with zero(s) just remove them before calculating (i.e. 0A fb=AFB).
If the new (calculated) code is less than 4 characters, insert zeros in the beginning (i.e. FBB=0f bb)
trdltly likes this.
bizzle is offline
The Following User Says Thank You to bizzle For This Useful Post:
post #5 of 54 Old 03-20-2019
Good thing for starting this topic, but I have to add some things regarding some mods that were present here:
1. Off-road tweak cannot be performed on newer model, the entire menu has been removed from the green-menu.
2. Oil temperature option has also been disabled in newer instruments cluster and so performing the adaption will result in a value out of range.
Tweetyblu is offline
post #6 of 54 Old 03-20-2019
Scubacruiser's Avatar
Define "newer"
Scubacruiser is offline
post #7 of 54 Old 03-21-2019
Everyone I pulled this from the C7 we should be able to use a lot of these mods
newest version provided by niuk26: http://tiny.cc/C7vcds
The Following User Says Thank You to Andrew149 For This Useful Post:
nm2003 (03-21-2019)
post #8 of 54 Old 03-21-2019 Thread Starter
Great find. Since external links always expire or just disappear lets try not to post those because that makes the thread useless. I went ahead and printed the Google Doc and attached it to this post.
Hopefully some of us can try the coding and confirm they work on our 7P models and then POST it into thread with success.
Sure wish the Oil Temp and Boost gauge would work. That would be cool to have. Of course I could just plug in my Scangauge.
trdltly is offline
post #9 of 54 Old 03-26-2019
New2Tregs's Avatar
Enter it as 'd3 c8'
Is this for the fault that appears in the 5F module if you update the firmware yourself without having it hooked up to the VW Mothership?
Yes I have a Vag-Com cable and software. No it's not from Ross-Tech but works flawlessly
New2Tregs is offline
post #10 of 54 Old 03-27-2019
That's my understanding. It's not the method I tried, but I also wasn't able to completely clear my errors. Hopefully I can try this tomorrow if I still have any errors and update the thread.
bizzle is offline
« VAG COM locator | - »
Summary of VAG-COM tweaks for the Touareg (T1) 2004-2007 spockcat VAG-COM 153 06-23-2018 11:44 AM
Volkswagen Genuine Accessories for the Touareg haso0on General Maintenance & Repair 0 10-23-2004 07:55 AM
touareg experience 2004 TOUAREG-HOLLAND Events & Gatherings 19 02-18-2004 12:55 PM
