Summary of VAG-COM tweaks for the Touareg (T3)(7P) - Page 2 - Club Touareg Forums
 11Likes
post #11 of 55 Old 03-29-2019
New2Tregs's Avatar
Originally Posted by bizzle View Post
That's my understanding. It's not the method I tried, but I also wasn't able to completely clear my errors. Hopefully I can try this tomorrow if I still have any errors and update the thread.
I'll wait for someone else to try this and report back on the results as to whether it worked or if they bricked their unit.
New2Tregs is offline
post #12 of 55 Old 03-29-2019
OK, I'll try it in a few minutes.
It didn't brick it but it also didn't resolve the error, either.
I haven't found anything that resolves error 03175.
bizzle is offline
post #13 of 55 Old 03-29-2019
New2Tregs's Avatar
Thankfully you didn't brick it.
Since the fault only shows up in 5F on a scan and affects nothing I'm going to leave it alone.
post #14 of 55 Old 03-31-2019
Touareg: 2017 V8 TDI
Hi All
Has anyone found a way to change the speed at which the air suspension automatically lowers from the offroad higher setting?
Brian
topline is offline
post #15 of 55 Old 03-31-2019 Thread Starter
Originally Posted by topline View Post
Hi All
Brian
Your 2017 would not be posted in this thread. You might try over here: https://www.clubtouareg.com/forums/f...st-230298.html
topline likes this.
trdltly is offline
The Following User Says Thank You to trdltly For This Useful Post:
topline (03-31-2019)
post #16 of 55 Old 04-01-2019
iSagen's Avatar
Touareg: 2011 V6 TDI
Battery Coding:
19 CAN
-> 10 Adaptation
(1)-Battery adaptation-Size # In Ah
(2)-Battery adaptation-Manufacturer #Three first letters on the BEM-sticker
(3)-Battery adaptation-Serial number
dynaudio profile for non dynaudio sound systems
1. Select the " 56 - Radio" unit.
2. Enter the section " 07 - Encoding " and press " Long encoding "
3. Byte 4 - replace the value 01 with the value 00
4. Save and exit
Aux. heater in RNS850
From factory this heater is used only after engine start, but its easy to make it work as a parking heater and activate timers menu in RNS.
1 In Hidden menu check option car/cardevicelist - Auxiliary Heater (RNS850)
2 set option Auxiliary Heater to 5 in car / carmenuoperation (RNS850)
3 set enabled bit 4 in byte 1 of 08-AutoHVAC module. (VCDS)
4 reboot the RNS850
Misc. climate
[Adaptation 10] -> From the drop-down menu select and adjust:
-Retention of Driver/passenger seat heater level. Default 10 minutes.
-Air recirculation when driving in reverse
-Air quality sensor sensitivity
-Store manual fan setting for terminal 15 off
-Store recirculation setting for terminal 15 off
Misc. Comfort
09-Cent. Elect. - Tear wipe, Lights On Warning, Various light changes
Security code: 20113
[Coding - 07] -> Long Coding Helper:
Byte 1 Bit 3 – Tear Wiping On or Off
Byte 2 Bit 6 – Dim Wink On or Off
Byte 3 Bit 2 – LED remain the same brightness (1 = Active)
Bit 7 – Turn off LED strip with indicator (1 = Active)
Byte 5 Bit 3 - Set to 0 to disable "lights are on" warning when you open the door
Byte 10 Bit 3 – Enable/Disable amber corner lights in front
Park assist
10-Park/Steer Assist - Park Assist Speed
[Adaptation - 10] – Select Switch-off speed from the drop-down menu for parking assist, set desired new value.
ACC
13-Auto Dist. Reg - ACC Distance Selection
[Adaptation - 10] – Select and change “Distance basic setting” from the drop-down menu.
This mod allows the selection of the default distance in the Car Settings menu.
Seat belts
17-Instruments - Seatbelt Chime
[07-Coding] - Long Coding - Byte 0 Seat Belt Warning active/inactive
Time
[Adaptation 10] - Drop Down List-> Select and change:
-Source for Synchronization of time - Select Manual or GPS
Key Warning
46-Central Conv
[Coding - 07] -> Long Coding Helper -> Byte 9 Bit 7 Enable/Disable Key Warning chime
Comfort Opening/Closing
[Coding - 07] -> Long Coding Helper -> Byte 2 Bit 0 Enable/Disable Comfort Operation. It must be Enabled (unchecked) for the adaptation codes to work.
[Adaptation 10] -> Select/adjust entries from the drop-down menu to configure the keys and various comfort opening/closing options. VCDS has help menus with each configuration’s code.
RNS850
5F-Information Electr. - Nav and Phone warning msg, WiFi, Green Screen, VIM
Security code: 02002
[Adaptation 10]
To disable NAV & Phone warning messages while entering data at speed change the following:
Channel 2 – Set to 250
Channel 3 – Set to a small number (5)
To enable the Green Screen:
Channel 6 - Change to 1 from 0 then press SETUP + CAR for several seconds.
A few useful setting on the Green Screen menus:
-Adjust the microphone sensitivity: diagnose/settings/tel_settings/Mic sensiblity -> choose -6db/0db/+6db. The default is -6db, I found that 0 db works much better with my iPhone.
-Increase radio play time after car is turned off:
From the main screen select “onofftimer”, set 'Standby delay'.
Default is 10, maximum value is 30 minutes.
- Enable Import CDs to MMI's HD:
main/diagnose/settings/import_multimedia -> Enable "Copy” and/or “Ripping"
Channel 19 – Enable/disable WiFi - does not seem to make any difference.
Enable Video In Motion (VIM):
[Advandced ID - 1A] - Submit the value from the "Serial Number" field into the web address: VIM login-code generator for MMI 3G
Alternate: Use Digits 6, 13, 10, 14, 11 of the Serial number (“-” = “0”)
[Security Access – 16] - Enter the five digit code received from the web address
[Adaptation – 10] - Channel 48 – change to 255 – Reboot RNS
Reboot RNS by simultaneously pressing Phone + Climate + Nav + Traffic + Central Knob.
Trunk
6D-Trunk Elect. - Tailgate open with trailer, Tailgate open with long push of remote button.
[10 - Adaptation] – From the drop-down menu, select:
- Opening with Trailer Detected and choose Activated
– Activate (4) remote key Tap for closing
darrenswift likes this.
iSagen is offline
post #17 of 55 Old 04-01-2019
New2Tregs's Avatar
Has anyone figured out how to change the comfort blinks from 3 to something else like 4 or 5 for the T3, or captured a clear up close picture of Bigfoot or Nessie or ET?
No seriously just the first one, although it seems just as elusive as the others.
post #18 of 55 Old 04-02-2019 Thread Starter
Has anyone figured out how to change the comfort blinks from 3 to something else like 4 or 5 for the T3?
I think it is called "Comfort Blink"
Have you tried:
09-Central Electronics
Select function 10 - Adaptation
In the adaptation window, select channel 02.
Note the stored value (should be 3).
Set the new value to x (x being the number of flashes you desire), and test the output.
Once test has run successfully, hit SAVE, then DONE.
trdltly is offline
post #19 of 55 Old 04-02-2019
New2Tregs's Avatar
Have you tried:
I think I wrote it correctly grammar wise.
Either way that doesn't exist for the T3, only on previous generations.
post #20 of 55 Old 04-02-2019 Thread Starter
Yes you did write it correctly. For some reason I did not see that in the initial post. I am running 19+ beta version of VCDS, so I will try to dig around.
LoL... you have been working on this one for a while - https://www.clubtouareg.com/forums/f...ml#post2009323
And over on OBDeleven's forum. I wonder if that is something we might find on the green screens?
trdltly is offline
Summary of VAG-COM tweaks for the Touareg (T1) 2004-2007 spockcat VAG-COM 153 06-23-2018 11:44 AM
Volkswagen Genuine Accessories for the Touareg haso0on General Maintenance & Repair 0 10-23-2004 07:55 AM
touareg experience 2004 TOUAREG-HOLLAND Events & Gatherings 19 02-18-2004 12:55 PM
