Summary of VAG-COM tweaks for the Touareg (T2) 2007.5-2009 - Club Touareg Forums
post #1 of 42 Old 03-23-2009 Thread Starter
Still Plays With Cars
aircooled's Avatar
Second Vehicle: 2006 V10 TDI
This purpose of this thread is to list and document all tested VAG-COM coding changes for the Touareg and Touareg2 with CAN-BUS controllers and long coding.
Please PM a moderator or admin to add TESTED coding functions to this list.
aircooled is offline
post #2 of 42 Old 07-21-2009 Thread Starter
aircooled's Avatar
From user Siberian:
For the T2s, 08s and newer to change the number of blinks:
09 Central Electrics
Adaptations
Channel 1
Change the New Value to whatever you want (I set it to 5)
Test
Engage the momentary indicator by depressing slightly
count the number of blinks and if it's doing what you want
SAVE
It will ask you whether you want to save the new number into WSCxxxx. Enter
YES
You're done.
Please note:
Channel 00 will reset all Central Electric Functions to Factory presets.
Channel 01 and not 02 is the one for the T2s
Enjoy
siberian
Please read our Club Touareg
and our
post #3 of 42 Old 05-12-2010
Supporting Member
Bails's Avatar
Touareg: 2009 V10 TDI
OK played some more and discovered Adaption Tab now have the 5 blinks. My apologies to those who spend the time reading instructions. Trust this helps the next Reader
Range Rover Sport SVD8 ,R50 R50 Biscay Blue gone, Had V10 TDi with everything,AUDI Allroad 2.7T Chipped sold, Audi TT Quattro TDi Sold , Audi SQ5 driven by my better half, BMW R1200GSW.
Bails is offline
post #4 of 42 Old 04-21-2012 Thread Starter
aircooled's Avatar
At the request of one of our members and to save some time, please post all related T2 VAG-COM mods and codes in this area. I know many have been posted in the forums and I would request that the members help us find them and collect them here. I will moderate the responses to "trim the fat" and the content to coding examples only.
and our
post #5 of 42 Old 04-26-2012
sierradeux's Avatar
More VAG changes to the T2 which work (at least on 2010's)
1) To get gear numbers alongside the D or S in the color MFI:
Recode tansmission control module (2) to 0004456. This code includes the
changes of code 4200 - ROW mode with higher shift points, better
downshifting, and hill hold in high range. If you have paddle shifters installed,
add 8192 to this code = 0012648.
Sometimes this works on the monochrome MFI, sometimes not.
2) To turn off the seatbelt chime, and telltale:
Recode module 17, fourth digit, typically 0007231 to 0005231.
3) To allow the reverse camera to stay on for 10 sec after shifting out of
reverse (great when jockeying back and forth to line up with a trailer):
Recode module 6C from US setting 0110001 to ROW setting 0010001.
4) To disable rain sensor from messing with your wiper delay speeds:
Open module 68. Choose "coding". Open the drop box. highlight the second item, which is the rear wiper. This will open long coding, defaulting to the first byte. Underneath, there are several check boxes, the fourth of which is "disable rain sensor". Check this box, test, and close. Delay wipers now default to two different sets of four fixed speeds each, depending on whether the vehicle is moving or still.
2017 Audi Q5 3.0 V6
2010 Touareg V6 TDI - repurchased by VW
2008 Audi A4 S-Line 3.2 V6
2005 Touareg V6 - sold
1985 Porsche Carrera Cabriolet - sold
sierradeux is offline
post #6 of 42 Old 04-26-2012
sierradeux's Avatar
...and one more for the T2
To get control of the DRL's into the MFI, so they can be turned on and off as desired:
Open controller 9, and select "coding". The long coding box will open with the current code highlighted. Copy the code (Ctrl-C) and paste (Ctrl-V) into the new code box below. Change the first two numbers from 23 to 22. Test and save.
Now disconnect the computer and VCDS cable, turn off car, remove key, get out and lock door. Wait 30 seconds, then unlock, and restart. You should now find "day lights" as an option in the MFI.
NOTE: on my 2010 with color MFI, the DRL's turned off as soon as I saved the new code. On the 2009 with monochrome MFI that we did last weekend, it took several power cycles before the switch option appeared in the MFI---your results may vary.
2017 Audi Q5 3.0 V6
post #7 of 42 Old 09-21-2013
jcmuscarello's Avatar
Is thereba book on all these codes out there somewhere? How do people know what's what??
jcmuscarello is offline
post #8 of 42 Old 03-18-2014
Touareg: 2009 V6 TDI
I reckon it's a lot to do with setting various settings based on region, you have things like DRL's that are required in some countries and not others. The other things, people playing around and finding stuff!
ScottieDucati is offline
post #9 of 42 Old 03-18-2014
Touareg: 2008 V6
I have a 2008 VR6 and all the codes work on mine except, for number one on the list, the one that shows the gear numbers next to D or S. Other than that I am very happy with the changes I made with the VAG COM
lfelix is offline
post #10 of 42 Old 03-19-2014
Perry01's Avatar
For some reason 2008 model cannot have the gear displayed next to D.
2016 AUDI A3 S-LINE
2015 Q5 PREMIUM PLUS
Perry01 is offline
Summary of VAG-COM tweaks for the Touareg (T1) 2004-2007 spockcat VAG-COM 153 06-23-2018 11:44 AM
More T2 Vag (VCDS) Tweaks ameoba VAG-COM 22 09-21-2011 04:16 AM
Tweaks for the site Swedie Club Touareg News & Announcements 8 12-12-2010 04:43 PM
VAG COM a 2009 Touareg jv91 VAG-COM 13 07-01-2009 07:25 AM
5K Mile Service Summary mustanghusker General Maintenance & Repair 1 01-21-2005 11:30 AM
