obd not working - Club Touareg Forums
post #1 of 5 Old 01-03-2019 Thread Starter
obd not working
well I pulled the keesy module out for soldering new fets all back together and my vag-com does not light up
I did have the panel hanging down for a little bit but doubt any wires broke
Any ideas, anyone?
coolbeans05 is offline
post #2 of 5 Old 01-04-2019
New2Tregs's Avatar
Hello and welcome to the forums.
Does the Kessy module itself work normally, aside from the Vag-Com not working?
I don't know what your soldering skill level is, but is there any possibility that you soldered two connections together when you did the work?
New2Tregs is offline
post #3 of 5 Old 01-04-2019 Thread Starter
Door handles still intermittent push button to start works
Still having same symptoms as before.
Checked vag com in other car and it is working properly
post #4 of 5 Old 01-05-2019
wolfman1959's Avatar
Touareg: 2006 V6 TDI
Second Vehicle: VW Bus
Do you have clamp 15 plus working ( direct german translation - Batterie plus switched on when key is turned via relay under driver seat)?
wolfman1959 is offline
post #5 of 5 Old 01-05-2019
Check fuses 7 and 51 on the left dash fuse panel. Realistically you should check all of them, but 7 and 51 are for the OBD port.
- OEM air suspension retrofit
- OEM parking heater retrofit
chewblekka is offline
