How to code an ABS pump? - Club Touareg Forums
post #1 of 15 Old 06-15-2014 Thread Starter
Touareg: 2003 V6
I've looked on the ross tech wiki and can't find any information on how to code the ABS pump. I've just put a replacement unit on my car and it's showing a coding error.
Escy is offline
post #2 of 15 Old 06-15-2014
Moderator
hedditch's Avatar
These may help
200? V6 Petrol - Coding: 0014338
2004 v8 Petrol - Coding: 0014594
2004 V10 - Coding: 0022785
2006 W12 - Coding: 0022786
included FYI, but I would suggest the first three would be applicable to your model.
2008 V6 TDI -Coding: 0004354
2010 V6 TDI - Coding: 0004482
kind regards
Stuart..
hedditch is offline
post #3 of 15 Old 06-15-2014 Thread Starter
Touareg: 2003 V6
Mine is a 2003 3.2 V6 petrol. I tried your code (001433 and it accepted it but I'm still getting the same error.
01044 - control module incorrectly coded
Looking at an old scan I did of my car before I swapped the pump, my original code was 0014337. I've tried putting that in but get an error message "coding rejected. error 31 - out of range"
Could it be that the pump isn't suitable for my car? It came off a V8 petrol. The part numbers were 7L0 614111F for the pump and 7L0 907379G for the ECU. The pump on my old one is the same number but with a B on the end. The controller is the same but ends with an A.
Escy is offline
post #4 of 15 Old 06-15-2014
Moderator
hedditch's Avatar
I think I know this one.... Check you copy of VCDS and make sure you DON'T have all zeros in your Workshop Code settings.. Anything other than zeros will be fine.. Zeros will throw 01044 error.
hedditch is offline
post #5 of 15 Old 06-15-2014
Moderator
hedditch's Avatar
The 0014338 coding is from a unit with a "G" series ABS unit..
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0014338
Shop #: WSC 31414 000 00000
VCID: 3D7B29BF1DE1
hedditch is offline
post #6 of 15 Old 06-15-2014 Thread Starter
Touareg: 2003 V6
It did have all zeros in the workshop bit, i've changed that and re-coded it and recoded the CAN bus, i'm still getting the errors.
I can code the 0014338 and it accepts that but I get the error. When I try 0014337 I get the error and it won't code it.
Escy is offline
post #7 of 15 Old 06-16-2014
Moderator
hedditch's Avatar
Sorry that's about my limit on the subject. Maybe somebody else could help. Have you tried sending an email to Ross Tech's support line. They are very good and responsive.
hedditch is offline
post #8 of 15 Old 06-16-2014 Thread Starter
Touareg: 2003 V6
Thanks for your help. Hopefully someone else has been in this position and can offer advice.
Escy is offline
post #9 of 15 Old 06-16-2014
I have been following you posts and can offer no other comment than i would have replaced like part numbers for like parts numbers not units from a V8 but from the same as yours a V6.
I wish you luck
Regards
Drag
dragline1570 is offline
post #10 of 15 Old 06-16-2014 Thread Starter
Touareg: 2003 V6
My understanding is that with VAG part numbers the letter at the end is what revision the part is and even if I bought brand new from VW they wouldn't supply a unit with the exact same number. Is that correct or not?
Escy is offline
