Easy Open trunk retrofit for 7P - Club Touareg Forums
 4Likes
  • 4 Post By chewblekka
post #1 of 8 Old 03-10-2019 Thread Starter
Posting this here as the DIY board is a mess and unusable.
Retrofitted the Easy Open trunk system to my 2015 Touareg R-Line today. It's shame that the R-Line trim doesn't get this incredibly useful feature, so I added it. I acquired the module, antennas and wiring harness off eBay. You can also find them on AliExpress. MAKE SURE YOU GET ALL 4 PARTS!
Parts needed:
Module with antenna and harness assembly 3AA-962-243-D or 3AA-962-243-E
Foam module holder 7P6-807-573-A
Remove the rear bumper. Here are the factory removal instructions.
Once removed, insert the module into the foam bracket/holder, then attach to the lower left side of the bumper, just inboard of the left tail pipe. The R-Line bumper has a slightly different contour than needed, so I attached the foam piece with RTV.
Next attach the antennas. I used RTV to attach my clips, you can also use double sided tape. Make sure you space the antennas about 2-3" apart, and that they run parallel to each other!
Check to make sure the harness connector is wired properly, mine wasn't. You should have a red/yellow wire in pin 1, a brown wire in pin 2, and a purple/yellow wire in pin 3. Now run the 3 wires into the trunk. I pierced a small hole in the rubber grommet that the existing bumper harness used. Attach the brown ground to the existing grounding point inside the left rear lower trunk floor, where the exterior harness come in. Run the remaining two wires up the the drivers under dash area. You can tuck the wires under all the kick panel trim. Connect the red/yellow wire from pin 3 to the fuse panel, position 34. Install a 5-amp fuse. Connect the purple/yellow wire to pin 18 of the BLACK 32-pin connector on the BCM.
Wiring diagram
Connect your VCDS and access module 46- Central Electric. Go to 07-coding, select "Long Coding helper". Go to Byte 13, and change its hex value from "00" to "02", or binary to "00000010". Test out the system by closing your doors and trunk and locking the car. Then, with the key on you, swipe your foot across the bumper parallel to the antennas. The trunk should open.
Put everything back together and enjoy your new Easy Open trunk! The trick to get it to work every time is to kick your foot up next to the right of the left tailpipe, the swipe it horizontally to the right.
- OEM air suspension retrofit
- OEM parking heater retrofit
chewblekka is offline
The Following User Says Thank You to chewblekka For This Useful Post:
Juha (03-12-2019)
post #2 of 8 Old 03-11-2019
Another great retrofit by you!
Tweetyblu is offline
post #3 of 8 Old 03-12-2019
New2Tregs's Avatar
That is absolutely brilliant !!
What was your total cost for the retrofit?
New2Tregs is offline
post #4 of 8 Old 03-12-2019
Touareg: 2011 V8 TDI
It seems that the wiring harness is about 76 dollars, and the foam piece 40 dollars. That's it.
Might be worth considering with these magnificent instructions.
Thanks chewblekka!
Does this go to pre-facelift = 2011 model with keyless access?
Juha is offline
post #5 of 8 Old 03-12-2019 Thread Starter
I think total cost was $110 CAD. $15 for the foam piece and $95 for the module/harness. This will only work on 2011+ with keyless/push button start and electric hatch.
post #6 of 8 Old 03-12-2019
kyle4171's Avatar
Second Vehicle: Old heap
Seems simple
kyle4171 is offline
post #7 of 8 Old 03-12-2019
New2Tregs's Avatar
So this will not work w/my 2011 with electric hatch but without push button start?
post #8 of 8 Old 03-13-2019
The car needs to recognize you before the hatch can be opened. Otherwise everybody could kick your boot open...
So, keyless entry is required, I guess.
Juha is offline
RNS-510 retrofit on a 2005 Touareg Steph Mobile Electronics and In Car Entertainment 70 11-26-2015 08:07 AM
PLEASE HELP..trunk suction and trunk opening????? rskreli General Maintenance & Repair 9 07-31-2009 11:56 AM
Can you open the glass when the trunk is already open? dunc_b General Maintenance & Repair 10 02-18-2009 09:59 PM
trunk open light appears, when trunk is closed bhayes7676 General Maintenance & Repair 11 05-30-2008 06:02 PM
Trunk wont open konstantinos General Maintenance & Repair 3 02-01-2008 05:14 PM
