2016 T3 Mods List - Page 3 - Club Touareg Forums
 14Likes
post #21 of 94 Old 05-06-2016
Touareg: 2016 V8 TDI
thankz for putting this together
Aust spec MY16 V8 TDi R-Line - Black Pearl - panoramic sunroof
nm2003 is offline
post #22 of 94 Old 05-06-2016
fincher's Avatar
Anyone tried installing the auto-hold switch on a 2016? Wonder if coding is the same as the 2012.
2017 Porsche Macan
2012 Touareg TDI Exec (Cool Silver/Anthracite) | Warning Triangle | Auto Hold Switch | (she gone)
fincher is offline
post #23 of 94 Old 05-07-2016
Safe lock message.
I've done a few of these mods on my 2015 TDI and now i got the "Check SAFELOCK" message after i remove the key from ignition.
Looks like it could be linked to the remote comfort opening mod...?
I've tried and you are really lock in the car if someone is left in it and you lock the doors, the inside handles dont open the doors (even if you pull 2x or more).
This can be a bit dangerous and would like to remove that fonction that was activated somewhere in the mod process, which i, have no idea where.
Jerome is offline
The Following User Says Thank You to Jerome For This Useful Post:
random1 (06-04-2017)
post #24 of 94 Old 05-07-2016
Philth's Avatar
Mine just arrived. Just need to buy a VAG com now to install it.
Philth is offline
post #25 of 94 Old 05-07-2016
Touareg: 2016 V6 FSI
No it is not, at least in US. See my post #11 and the OP's post #1. You'll need VCDS software and cable to effect these changes.
Originally Posted by Philth View Post
Is this option enabled already? Sounds like it is from what I've been reading? If so, I haven't been able to figure it out.
KT88 is offline
post #26 of 94 Old 05-07-2016
fincher's Avatar
Keep us posted. Love it on my 2012.
2017 Porsche Macan
fincher is offline
post #27 of 94 Old 06-30-2016
RossSettle's Avatar
Touareg: 2013 V6 FSI
To get the sunroof to open fully rather than tilt via the key fob try:
46-Central Conv.> Adaptation 10>Channel 61> New value 1755>Test>Save>Done, Go Back
DennisL likes this.
RossSettle is offline
post #28 of 94 Old 05-30-2017
Originally Posted by NMReg View Post
It's been a long while since I posted anything but I have traded my trusty 2005 V8 'Reg for a new one late last year, so now I have a list of mods that I made on my 2016 TDI Lux that think would be of interest to everyone with a late model T3 'Reg.
I still have a wish list, so if anyone knows how to code these, I would love to hear about it:
Retain steering wheel heat setting
Auto closing (without having to touch the indentation on the door handle)
Rain Closing of windows and sunroof
Oil Temp Display
Parking brake release without seatbelt on
Battery Status Display
Enable Google Map
So, here goes the list of tested mods listed in order of the control modules. These all work on my 2016 TDI Lux.
I collected these from many different sources, so I am not taking credit for anything more than to list them in one place.
02-Auto Trans Enable Gear Display
[Coding - 07] -> Long Coding Helper -> Byte 1
Change Byte 1 from 00000010 to 00000101 (Hex 02 to 05)
Original code: 01 02 00 00 0C 00 84 00000000000000000000000000
New Code: 01 05 00 00 0C 00 84 00000000000000000000000000
The transmission needs to be reset for this change to take effect.
Reset transmission:
1. Selector in P
2. Ignition on, no start
3. Accelerator to floor for 30 seconds
4. Release accelerator
5. Ignition off
6. Lock doors
7. Unlock doors
03-ABS Brakes Enable Auto Hold
First, need to replace the parking brake switch in the center console with a European version, P/N: 7P1 927 225A
This can be easily bought from European e-bay sites for about $30 plus shipping. Note: the illumination of the switch is red, not white.
Replacing it is pretty simple. It is a direct plug-in, there are several detailed descriptions on how to do it with pictures on VW sites.
Then the following coding change needs to be made:
[Coding - 07] - Byte 16 Change 01110011 to 01110111 from 73 to 77 in binary.
Original code: 5B 76 13 C3 49 24 6F 57 DA FA C8 93 92 D6 F6 60 73 01
New Code: 5B 76 13 C3 49 24 6F 57 DA FA C8 93 92 D6 F6 60 77 01
[/FONT]
Some questions, I'm glad you've listed the part number thanks so much. I just got VCDS up and running and a cable and I definitely want to do this modification. However I can't see any guide on how you detach the old button and fit the new one? is it clipped in?
I'm just hesitant to order it, as its $68 US dollars +shipping and $98 from VW directly, I cannot find one for $30 plus shipping please send me a link if you know one.
Thanks ill wait to hear from you
LukeSmith1994 is offline
post #29 of 94 Old 05-31-2017
Learner
Singh's Avatar
Second Vehicle: 2015 V8 TDI
Subscribed. Thanks
Singh is offline
post #30 of 94 Old 09-24-2017
I did the auto hold switch upgrade to a 2016 Executive. Works great!
skelly14 is offline
The Following User Says Thank You to skelly14 For This Useful Post:
radef (12-06-2018)
2016 t3 , vcds vag-com
