2016 T3 Mods List - Page 2 - Club Touareg Forums
 14Likes
post #11 of 94 Old 04-09-2016
Touareg: 2016 V6 FSI
KT88
Thanks! Great post and I just completed gear display, seat belt chime disable and a few others. The one below did not work too well for me. Disable Comfort Operation was already unchecked. What I found is I had to check the enable Remote and Enable Advanced Key options. I also found out that messing with Adaptation actually kept my windows from opening and closing so I reset those back as they were. The last step was to go into the Car menu, find the new menu item "Vehicle Key" and check the three items Front Windows, Rear Windows and Sliding Roof to enable their operation with the remote via "Press and Hold to open."
Originally Posted by NMReg View Post
46-Central Conv - Comfort Operation, Key Warning, Remote Key Coding, Open-Close Adaptation codes
Comfort Opening/Closing
[Coding - 07] -> Long Coding Helper -> Byte 2 Bit 0 Enable/Disable Comfort Operation. It must be Enabled (unchecked) for the adaptation codes to work.
[Adaptation 10] -> Select/adjust entries from the drop-down menu to configure the keys and various comfort opening/closing options. VCDS has help menus with each configuration’s code.
KT88 is offline
post #12 of 94 Old 04-28-2016
This thread must be made sticky - without hesitation . Post gets a thanks! As soon as I am in front of a pc.
I got my 2015 yesterday, and tried fiddling with vagcom based on everything I've learned from my cc and gti. This seems to resemble my cc r-line far more than the mk7 gti. I hope to help you discover some of the ones you're missing, as they are of interest to me too. I've done tons of vagcom tinkering in the last 10 yrs or so, but never on the Touareg.
My '15 is an execline r-line, and a remote starter, so I am additionally interested in:
* whether or not I can re-add hands free hatch open which is deleted on rline
* set memory of seat heater on front *and rear* seats when turning on in the morning
* rain sensing sunroof close
* open roof (not just raiseed) when openimg windows via keyfob.
Thay last one may not be possible, but I threw it out there just in case. My CC didnt have a retractable roof, and I wasn't able to do it on the mk7 gti.
sandr0id is offline
post #13 of 94 Old 04-28-2016
yuyueyuyue's Avatar
Touareg: 2012 Hybrid
seat heater memory can be set in HVAC adaptation.
roof will open with comfort opening, you just need to hold it long enough.
yuyueyuyue is offline
post #14 of 94 Old 04-28-2016
yuyueyuyue's Avatar
adjusting heated steering wheel temperature.
https://www.clubtouareg.com/forums/f8...re-236457.html
post #15 of 94 Old 05-01-2016
Has anyone made any progress on the oil temperature display?
I'm highly annoyed that I can't figure out how to add this.
I Might try calling Ross-Tec next time I have some time during business hours.
UnXpectedError is offline
post #16 of 94 Old 05-01-2016
Philth's Avatar
What is comfort opening?
Also, does this vehicle close windows if the rain sensor is wet?
Philth is offline
post #17 of 94 Old 05-02-2016
Anybody succesfully changed the push-to-talk to mute?
KrUsTyX is offline
post #18 of 94 Old 05-06-2016
Comfort opening/closing windows/sunroof with remote. Nice to open her up on a hot day before you arrive to drive off .... or to close her up from office window (I'm 20 ft away) if it starts to rain.
No clue as to closing with rain sensor.
KT88 is offline
post #19 of 94 Old 05-06-2016
Oregon TDI's Avatar
My theory is that the software controlling the driver's MFD has no Oil Temp option to toggle on/off by VCDS. VCDS thinks it does because it was there in earlier model years. But at some point it was removed from the software.
In short: The oil temp data is available but there's no software to display it.
I would welcome being proven wrong.
Oregon TDI is offline
The Following User Says Thank You to Oregon TDI For This Useful Post:
kenrick118 (04-30-2017)
post #20 of 94 Old 05-06-2016
Philth's Avatar
Is this option enabled already? Sounds like it is from what I've been reading? If so, I haven't been able to figure it out.
Philth is offline
2016 t3 , vcds vag-com
