replacing dust and pollen filter element - Club Touareg Forums
post #1 of 35 Old 06-20-2008 Thread Starter
hello. here i will explain how to replace the dust and pollen filter element. or what is commonly known as A/C air filter. this is on my 2005, V6.
it should be the same for V8 and for new models as well.
i needed to replace the filter, because i felt that its blocked by dust, because we are in a sand storm for more than 6 weeks now . and im always using A/C.
the filter is located inside the front passenger footwell.
all u need to do is to pray off the front passengers footwell cover ( black, where the footwell light is ) from the middle carefully. it should come out easily. using a wedge might help, but i didnt need anything to remove it.
after its been out of its front mounts. unplug the wires to the footwell light. and pull the cover out away from its rear mounts.
then you will notice, on the center console side, the filter housing. covered by a plate that is fixed with 2 screws. the socket size that should fit, is in SAE size. not metric (because its larger than 5mm and smaller than 6mm ). and since i had non. i used an adjustable wrench to remove them ( VERY easy ). then pull the cover to open.
after opening, gently press on the housing, and the filter should fall down.
remove it by squeezing it from the middle, its very simple.
clean it using blower, or replace the filter.
just remember for fitting, you must make sure that the filter guide is in proper position where it should fit on the filter housing.
put everything back on.
enjoy.
im listing pictures that should help.
Baido is offline
post #2 of 35 Old 06-20-2008
Still Plays With Cars
aircooled's Avatar
Second Vehicle: 2006 V10 TDI
Great writeup! Thanks for sharing.
Please read our Club Touareg
and our
aircooled is offline
post #3 of 35 Old 06-23-2008
zerokewl's Avatar
Wow! Nice...Thx
2004 , V6 All-options, minus 4-climatic control, minus rear view camera, minus DVD-Nav (only CD Nav), minus Adaptive headlights, minus Suspension control, minus Heated steering wheel
zerokewl is offline
post #4 of 35 Old 08-09-2008
TX-T-Reg's Avatar
Easy as you said it was....
Lot's of crud in the old one, so it was time.
Current:
2004 VW Touareg V8
2001 Porsche Boxster S
2007 Ford F-150 (son's graduation present, but on my dime....)
TX-T-Reg is offline
post #5 of 35 Old 08-10-2008
Flipper Dog's Avatar
Having a right hand drive vehicle some of the user tips can become lost in our market, but saying that it is good to see that the fliter is also on "our" passenger side (the left hand side).
I just followed the directions and was able to carry out this simple task....now were is my battery again
Flipper Dog
Now - Audi Q5 TDI and Golf R Line.
Retired - 2nd gen (T3) V6 TDI -
Very big hole in roof / Vanilla flavoured outside / Black Nappa inside with a brush of aluminium / OEM tow pack / Dark glass windows / Lots of cameras / Warm wheel with paddles / RNS850 / Extra real spare wheel / Some other stuff.
Had but now gone
Facelift (T2) V6 TDI-
Sun roof / Shadow Blue outside / Anthracite cow inside / tow pack. Now in a loving new home.
Flipper Dog is offline
post #6 of 35 Old 08-10-2008
JKUCSMA's Avatar
Touareg: 2008 V6
nice,thanks,how often to you change it under normal driving?
08 TouaregV6 Uniblack,Lux pckg,Nokian WRG2 SUV,255/65/17.,09 CC 4Motion,Black on Black
JKUCSMA is offline
post #7 of 35 Old 10-22-2008
Commercial Member
Another DIY is here with a few different pictures
Touareg Cabin Pollen Filter Swap
Dick and Nancy Lorntson
Founders and Owners
Precision Frame & Alignment, Inc. (now retired)
size="1">Our Fleet:
1949 VW Type 1, 1955 3-fold, 1956 Vert, 1957 23 window euro deluxe, 1962 ragtop, 1963 double cab, 1966 SO44 Westfalia Poptop, 2004 V10 TDI
DicknNancy is offline
The Following User Says Thank You to DicknNancy For This Useful Post:
Calibre (02-15-2016)
post #8 of 35 Old 11-25-2008
Thumbs up
Thanks for the tips, it was great knowing I needed a 5.5 mm socket. I bought a cheap kit from AutoZone that included a 5.5mm socket for around $6.
I pulled the filter out and thought I'd offer some lessons learned.
1. if you've got really bad allergies, you might want to get a fan out to blow the dust away when you pull the cover off. Mine had never been replaced, Date of MFG was 10/2003 and all sorts of debris fell out. I'm not terribly allergic but my eyes were itching a few minutes into it.
2. I'm a big guy, my garrage is small so I couldn't open the door all the way, not a good idea, I bumped the door into the wall, no harm done but unless you're a yoga master perform this service where you can open the door fully
3. Have a vacuum handy for clean up
Good luck.
ps. pics attached of my filter and all the debris/gunk
safford1977 is offline
post #9 of 35 Old 03-06-2009
One more step for 4 zone or '08
There is one more step. Probably a 4 zone issue vs. '08 (T2) issues, but there is a little piece of duct that you need to pull out of the way to gain access to the filter cover. No big deal, just has some friction clips to hold it in place. Thanks for the right up and pics though. Wouldn't have had the confidence to keep pulling on the cover if I didn't know it would come down. The clips were pretty tight on mine! Thanks again.
Cave Creek Alt Fueler is offline
post #10 of 35 Old 06-22-2009
Good luck.
For those concerned about a 5.5mm socket/nut driver - you can use a 7/32 socket/nut driver with no problem on this job.
2005 V8, Venetian Green, no mods
Green Egg is offline
how to change the pollen filter? reddy General Maintenance & Repair 17 05-10-2009 12:37 PM
Interior gets a lot of Dust! TonyE General Maintenance & Repair 12 06-16-2008 07:52 PM
pollen filter replacement bulahee General Maintenance & Repair 3 06-10-2007 03:12 PM
Dust and Pollen Filter wknoll General Maintenance & Repair 4 04-12-2007 03:30 PM
DIY Changing the 2004 V10 pollen filter - Pictures nlorntson General Maintenance & Repair 3 04-11-2007 10:50 AM
