Coolant loss. Need some help identifying a part number. - Club Touareg Forums
post #1 of 14 Old 3 Weeks Ago Thread Starter
Laggyband's Avatar
Touareg: 2007 V6
Hi guy's,
My Treg cooling system has succumb to the dredded plastic rot all VW's seem to suffer with.
Last night the pipe which goes around from just behind the HP pump, then behind the alternator, under the exhaust manifold, behind the engine mount and onto the rear split.
I need help identifying the part so i can source one.
The car is a BKS engine, VIN WVGZZZ7LZ8D029158. JXX gearbox.
Does anyone have access to ETKA and could find the part.
Laggyband is offline
post #2 of 14 Old 3 Weeks Ago
Go to 1stVWParts.com
You can put in your Vin# and should be able to find the part.
Laggyband likes this.
post #3 of 14 Old 3 Weeks Ago Thread Starter
Laggyband's Avatar
Touareg: 2007 V6
It looks like they only list the 5.0 V10 and not the 3.0 V6 tdi
Black 2007 V6 tdi, Air Suspension, Sat nav (RNS510), 6 disc multi changer, ipod integration, Black & cream leather, Sunroof, Full electric memory seats, electric memory folding mirrors with entry light, dynaudio package, quad zone climate, reversing camera, electric tailgate, bi-xenon 'follow the road' headlights, boot liner(s).
post #4 of 14 Old 3 Weeks Ago
It looks like they only list the 5.0 V10 and not the 3.0 V6 tdi <img src="https://www.clubtouareg.com/forums/images/smilies/icon_sad.gif" border="0" alt="" title="Sad" class="inlineimg" />
Ektacc website
Regards
Drag
dragline1570 is offline
post #5 of 14 Old 3 Weeks Ago Thread Starter
Laggyband's Avatar
Touareg: 2007 V6
Laggyband
Well that's been fun---its not plastic rot--it seems VW have installed metal connections onto the engine (Thank F!%K for that) and the pipe which has failed is the fist example of bad workmanship from the manufacturing division whom make pipes.
The pipe is 059121075 and looks to have had a hole blown in it when a nozzle was welded on and its been filled with Paint. The paint has lasted 12 years and just let go last night. Removing the engine mount was real fun it took 4 hrs to get it out.
Anyway its out and generally looks in great nick other than the hole.
ID:	223323   Click image for larger version
post #6 of 14 Old 3 Weeks Ago
Bad luck but good thread and it always helps with pictures.
Laggyband (3 Weeks Ago)
post #7 of 14 Old 3 Weeks Ago
Hmmm... Apologies the 1stVW site did not pan out. It is possible that they could be limited to North America Models. The site is ran by an actual VW dealer.
Drag mentions Ektacc which google links to www.oemepc.com.
What is the repair plan? Replace or get the existing metal pipe fixed?
post #8 of 14 Old 3 Weeks Ago Thread Starter
Laggyband's Avatar
Touareg: 2007 V6
One of the steps off Erwin says 'remove the 4 bolts and 1 nut then lift the engine mount bracket off the mount'
It should have said 'after solving world peace simply.....'
post #9 of 14 Old 3 Weeks Ago
Wow remove the engine to fix a coolant [email protected]? Unbelievable....
HAVE FUN!
-JAKE
NEW TO ME 2014 T3 LUX HOLE IN ROOF TDI (DUH)
SOLD 2010 VW JETTA SPORT WAGEN TDI (DUH)
TDI
TDI FAN BOY is offline
post #10 of 14 Old 3 Weeks Ago Thread Starter
Laggyband's Avatar
Touareg: 2007 V6
The engine does not have to come out, i had to make a spreader beam to hold the corner of the engine up about 25mm so the engine mount could come out, the engine is still connected the opposite side and at the gearbox:
On the 2nd picture where you can see the four mounting faces on the (Black dirty) engine mount, the slot between the 4 points is the path the coolant line runs through, and as the line has crimped on ends and a tee piece there is no way it will come through so the mount has to come out.
ID:	223365   Click image for larger version
ID:	223369   Click image for larger version
Just scanned new car - 1 fault found flash1975 General Maintenance & Repair 2 07-09-2014 02:49 PM
Vag-Com Programming questions: 2013 Touareg LUX compared to 2012 Audi Q7 Prestige - bregmanr VAG-COM 0 09-11-2013 02:10 PM
T1 W12 KM/H speedo to Mph RayC2 VAG-COM 10 02-11-2013 02:16 AM
WTH just happened? ameoba General Maintenance & Repair 16 10-15-2011 06:01 PM
