Occasional starting problems - Club Touareg Forums
post #1 of 10 Old 01-19-2019 Thread Starter
Agil's Avatar
Touareg: 2007 V6 TDI
Question Occasional starting problems
Hi! I would apreciate your help!
I have a 2007 V6 3.0TDI Touareg, and I have already spend 1.500, and the problem pressists!
When the car is coold it start's without at 1st! After driving, if I stop and try to start imediatly it starts also at 1st!
Howerver, if I wait 10 min, it won't start! the starter runs for 2 seconds and then nothing! only after 30 min!
Ive already changed the battery, starter, temp sensor and I still I've the problem!!
I've read in a post it could be "clogged up flap in what is the EGR valve assembly". Do you think it coud be my problem? Why it only happens when the car is warm??
I thank you in advance for your help...
V6 3.0TDI 2007
Agil is offline
post #2 of 10 Old 01-19-2019
Try also posting your problem on the UK site to widen your audience:
www.mytreg.com
post #3 of 10 Old 01-19-2019 Thread Starter
Agil's Avatar
I forgot to mention: no faults on VCDS.
the foult I had was from the sensor that was repalced
V6 3.0TDI 2007
Agil is offline
post #4 of 10 Old 01-19-2019 Thread Starter
Agil's Avatar
Thanks for the tip!
Im trying, however it says "You cannot start a new topic"
What do I have to, so I can start a new topic??
V6 3.0TDI 2007
Agil is offline
post #5 of 10 Old 01-19-2019
To stop spammers the first post has to be in new member introductions and be approved by admin so write your 1st post here :
https://www.mytreg.com/index.php?/fo...introductions/
post #6 of 10 Old 01-19-2019
Failed G28 engine speed sensor.(guaranteed)
LHS rear of engine down low.
Fairly easy to get
VW# 070 957 147 (off course expensive for a VW box holding a Bosch sensor)
Bosch # 0 261 210 261 (1/3 of the price)
All T1 and T2 V6 tdi owners should get this replace after about 180,000 kms
Regards
Drag
dragline1570 is offline
post #7 of 10 Old 01-20-2019 Thread Starter
Agil's Avatar
Thanks Drag!
I will try to replace the "G28 engine speed sensor" tomorrow! [IMG]C:\Users\bugag\Desktop\VW# 070 957 147.jpg[/IMG]
I realy hope you are right! I will give feedback after!
Regards,
Gil
V6 3.0TDI 2007
Agil is offline
post #8 of 10 Old 01-24-2019
Thanks Drag!
Regards,
Gil
And the outcome is?????
regards
Drag
post #9 of 10 Old 01-24-2019 Thread Starter
Agil's Avatar
You were right!
Problem solved!
engine speed sensor (G2 with problems
After replacement, no problems in starting when engine is warm!
For my Touareg V6 3.0 TDI (BKS), 2007, the PN is VW # 077905381K
Many thanks for your tip!
Regards,
Gil
V6 3.0TDI 2007
Agil is offline
post #10 of 10 Old 01-24-2019 Thread Starter
Agil's Avatar
I was hopping that maybe with the replacement of this engine speed sensor G28, the other problem that I have could be solved, but unfortunately not!
My cruise control does not activate! Also no errors on the VDS!
Drag!
Do you have some tip also to this one?
Regards,
Gil
V6 3.0TDI 2007
Agil is offline
