Brake disc size - Club Touareg Forums
post #1 of 14 Old 11-21-2014 Thread Starter
Touareg: 2006 V6
Brake disc size
Hi guys
I have a T1 V6 Diesel Altitude, can someone please confirm the size of my brake discs. I have checked on websites and they vary from 308mm, 330mm and 350mm for the fronts.
I'd like to buy the largest but not sure if they would fit the callipers.
stewartw is offline
post #2 of 14 Old 11-21-2014
The Moderator!
Yeti's Avatar
You should have 330 on that. 350 was only for the V10 TDI and I have to guess the 308 was for the R5. 330 is what you need to install on that vehicle.
Yeti is offline
post #3 of 14 Old 11-21-2014
No, you can't interchange disc sizes [rotor sizes] willy-nilly!
post #4 of 14 Old 11-21-2014
I ordered the 350 by mistake and they won't fit.
Zgaey is offline
post #5 of 14 Old 11-21-2014
Touareg: 2007 V6
Look up the brake system codes for the front and rear on the production sticker in your manual, then use the codes to find the correct parts using Pagid's e-catalog. Brake Pads | HELLA PAGID
For example, if your front calipers are 1LE and the rears are 1KQ, then:
1LE:
Pagid T1499
for brake disk diameter [mm] 330
T1499
Brake Pad Set, disc brake
Front Axle; Thickness [mm]: 17.1; Width [mm]: 131.8; Height [mm]: 77.2;
Brake System: Brembo; Prepared for wear indicator
1KQ
Pagid T1500
Rear Axle; Thickness [mm]: 17.1; Width [mm]: 86.9; Height [mm]: 70.1;
You can also cross reference the above codes to other brands, such as TRW (another ECE Regulation 90 certified pad). I have been using Pagids pads (they make the VW Brembo pads) and German TUV certified Zimmermann rotors. It is hard to find TRW pads, but members have reported that they are less dusty than Pagids, similarly effective, and lower priced. I would not use weak pads without the Euro R90 certification.
https://www.clubtouareg.com/forums/f4...tml#post344951
https://www.clubtouareg.com/forums/f4...tml#post861721
SamT is offline
post #6 of 14 Old 11-23-2014 Thread Starter
Touareg: 2006 V6
Hi Guys
Ok Thx for the info, I will order the 330mm for the fronts.
Just 1 more question, is the rears the same 330mm or 314mm.
This website is showing both sizes for the rears but only show 330mm for the fronts. So i'm not sure on the rears.
EBC Brakes Direct Automotive
Ok this is confusing. on this site if you click on the pads front or rear they are coming up with different sizes?
stewartw is offline
post #7 of 14 Old 11-23-2014
The Moderator!
Yeti's Avatar
Originally Posted by stewartw View Post
Hi Guys
330mm on both ends of your rig.
Yeti is offline
post #8 of 14 Old 11-23-2014 Thread Starter
Touareg: 2006 V6
OK Thanks YETI
stewartw is offline
post #9 of 14 Old 09-27-2015
Daveboy's Avatar
Touareg: 2006 V6
Second Vehicle: 2006 V6
I have just replaced all my discs front and back with M/TEC DISC'S drilled and grove front 330mm and rears 330mm powder coated i have altitude V6 TDI 3.0 2006.Remapped too around 300bhp.
Daveboy is offline
post #10 of 14 Old 09-27-2015
Hope you don't go offroad with these. Mud and grit stuck in holes will score everything to buggery.
