Oil pan - drain Plug stripped threads - Club Touareg Forums
post #1 of 15 Old 03-25-2016 Thread Starter
Touareg: 2012 V6 FSI
Greetings from Denver Colorado,
Got the big surprise after the oil change, that the bold spins and does not tight anymore. The mechanic said that I need a new oil pan and the whole thing will cost $2000, since they have to remove the whole Engine to replace the oil pan. I have read about Helicoil, but the shop said they can't find the kit for VW Toaureg.
Any comments or ideas are welcome, since I am not looking forward to spend $2000.
Thank you,
edupin is offline
post #2 of 15 Old 03-25-2016
How about an oversized drain plug? They're designed to bite into the old metal and create new threads.
post #3 of 15 Old 03-25-2016
Oversize is the way to go - even if you have to buy an oversize tap and make new threads. I can buy a very fancy tap for $2K!
Fourdiesel is offline
post #4 of 15 Old 03-25-2016
Second Vehicle: 2015 V6 TDI
Ecoplug, problem solved:
https://www.clubtouareg.com/forums/f4...cs-220706.html
Forget all those other, old fashioned ways of trying to fix a problem. The Ecoplug is the cheapest and easiest solution. I've had mine in since October and it has been perfect. $23 shipped.
I bought one for my wifes 2015 for the next time I need to change her oil.
http://www.ecoplugsystem.com/
BenTDI is offline
post #5 of 15 Old 03-25-2016
use a 25m x1.5mm tap for a standard plug.
I think toyota uses this size in a truck , anyhow search amazon.
mghamms is offline
post #6 of 15 Old 03-25-2016
here is a plug that will work:
More Information for DORMAN 090041
and another I like these:
http://www.amazon.com/25mm-Magnetic-...eywords=25+1.5
mghamms is offline
post #7 of 15 Old 03-25-2016
Built4Sin's Avatar
I've never seen that Ecoplug, that's cool!
| Cayenne TT Sways |
Built4Sin is offline
post #8 of 15 Old 03-26-2016
I had the two free/included oil changes done by two different dealers and one of them screwed up my drain plug/hole. I came accross the Ecoplug from someone on here and it really does work.
It is so simple, just the finned shaft and the magnet, and it works. Solved my problem forever, no need to buy new washers or plugs every change.
BenTDI is offline
post #9 of 15 Old 03-26-2016
No ecoplug listed to replace our V8 24mm plug.
mghamms is offline
post #10 of 15 Old 03-26-2016
If they stuffed it they fix it - at their expense.
JimJ is offline
