engine coolant temp - Club Touareg Forums
post #1 of 13 Old 06-23-2011 Thread Starter
Touareg: 2011 V6 TDI
engine coolant temp
This 2011 TDI Sport is my 9th diesel, so I'm not a novice. All my previous diesels had thermostats between 70C and 85C (160F-185F). Yet this Touareg wants to run at an indicated 210F (instrument panel gauge). Sending unit and gauge work, because I can see the temp rise as the engine warms up. But then it stops at 210F, and doesn't move anymore. I don't even see the (expected) gauge movement that reflects the thermostat opening and closing. Can it possibly have a 100C thermostat, or is this something I should have checked out? No check engine lights/faults/codes by the way.
Checked with service manager at 2 different dealerships. One danced around the question, said he'd have to plug in the car. The other promised a callback, then didn't. So I'm hoping for real-world input from other US-spec 2011 Touareg TDI owners (3.0 engine). Because from what I've seen since owning this vehicle, they seem to know more about their cars than do the VW service reps (in my area).
//greg//
grohgreg is offline
post #2 of 13 Old 06-23-2011
Moderator
hedditch's Avatar
FYI - My 2008 V6 TDI sits as steady as a rock on 90 C and does not move, either in mid summer at 40 C or Last week in Canberra at 2 C.... I think 100 C (210F) sounds a little high...
hedditch is offline
post #3 of 13 Old 06-23-2011
Second Vehicle: 2014 V6 TDI
The manual says normal operating temp is in the center of the gauge, which on US models is 200F which is where mine runs.
wensteph is offline
post #4 of 13 Old 06-23-2011
CADman_ks's Avatar
90F day here today, and I checked on the way home, and my temp was at 200F the whole way, which as indicated, is the middle of the gauge, straight up and down...
CADman_ks
CADman_ks
2011 Touareg Lux TDI
Black / Saddle Brown
CADman_ks is offline
post #5 of 13 Old 06-23-2011
Moderator
hedditch's Avatar
Further to what I said, 90C is also the middle of the gauge (straight up at the top).
hedditch is offline
post #6 of 13 Old 06-23-2011
To the point of needle movement above the 'set' point - whatever that may be. The ONLY time you should see ANY needle movement above the set point is if there is not enough cooling. ie you are pulling a long grade under heavy load such as pulling a trailer AND the cooling system is dirty or partly plugged.
Otherwise, as the motor throws off more heat, the thermostat just opens a tiny bit more and allows more coolant through to be cooled by the radiator etc. As the engine load increases it keeps on doing that until not enough cooling is available from the radiator. Only then does the temp actually rise a measurable amount.
Fourdiesel is offline
post #7 of 13 Old 06-24-2011
BANNED
my temp gage is always in the twelve o'clock position when warmed up(210f) and stays there
nltomba is offline
post #8 of 13 Old 06-24-2011
CustomSpooling's Avatar
//greg//
Volkswagen run their diesel engines at 90 degrees - Helps to achieve an optimal burn. It is perfectly normal. I would only get worried if the hand passed the twelve o clock position.
CustomSpooling is offline
post #9 of 13 Old 06-24-2011 Thread Starter
Well, that's consistent with the Jetta 1.9 TDI owners input. Their 12 o'clock position is said to be 90C (194F). But 12 o'clock on my 3.0 TDI is 200F (93C. And my needle runs pretty consistently at or near 210 (almost 100C).
It's either a false indication, or 210F isn't hot enough to trigger an ECM fault. Two VW service managers have failed to come up with an explanation, which is why I'm trying here.
//greg//
grohgreg is offline
post #10 of 13 Old 06-24-2011
I believe modern emission controls need higher operating temps. My V-10 has run at water temp 200 and oil temp 200-210 (depends on whether or not I'm towing. I've never seen either go above those numbers even when pulling a grade. This leads me to believe the total cooling capacity is adequate.
I believe the thermostats are electrically operated and controlled by the engine computer. As a result one will not observe the "traditional" changes in water temperature due to thermostats opening and closing.
johnt
johnt is offline
V10 TDI, cold weather and low coolant temp aircooled Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 29 11-07-2014 08:04 PM
Coolant temp issue 00_Bora General Maintenance & Repair 36 11-28-2011 07:34 PM
Whats considered a high coolant temp delstour General Maintenance & Repair 1 02-09-2011 07:13 PM
Cold Weather Coolant Temp Question AndrieK General Maintenance & Repair 3 06-30-2009 12:31 AM
Engine coolant temp G62/ VAG-COM 16502/P0118 fault AIR S2 General Maintenance & Repair 3 02-21-2007 09:41 PM
