Want to Buy: Need both cats for 06 V6 treg - Club Touareg Forums
post #1 of 6 Old 01-21-2012 Thread Starter
I was just given the bad news that i need both catalysts for my 06 touareg. If anyone knows where to purchase please help. I was just about to post it for sale so i can purchase a jetta TDI for my new commute.
Thanks, Cory
californiacanadian is offline
post #2 of 6 Old 01-21-2012
The Moderator!
Yeti's Avatar
How many miles are on your Treg? They are supposed to have a warranty on them to get them replaced in the event they go bad. Cats just don't go to crap like that. Are you sure they are bad?
Yeti is offline
post #3 of 6 Old 01-21-2012 Thread Starter
I have a 105K on it. It has the platinum extended warranty unyil 109k. At 82K i brought it in for the coil recall. It was running terrible at the time and had the mill light on. After that it stayed off for about 5K but came on. Now i can smell fuel and it has a bad hesitation when started. VW told me both cats are bad. I am going to call VWOA and complain. He said most likely the coils caused the cats to be damaged.
post #4 of 6 Old 01-23-2012
if it has a warranty until 109 and you only have 105 on it now I fail to see the problem. get it warrantied and call it a day. Or as a alternative fix you can install spacers for your O2 sensors O2 Oxygen Spacers sensor Dry Cell Test Pipe extension testpipe 18mm M18 X 1.5 * | eBay
these will bring your downstream O2 sensor out of the exhaust stream so you do not get a check engine light for catalyst efficiency below threshold. Then you can gut your cats and enjoy improved mpg and power. You will not pass a sniffer test if you have to get one.
somedude is offline
post #5 of 6 Old 01-23-2012
Touareg: 2009 V8
I'm assuming you are in California, if so, good luck finding a shop that will "jimmy" emissions. Not worth loosing a license for...try buying some Cataclean - you might be able to clear the Cat a bit. Note: It might also be the O² sensors. Ask your dealer if the "sensor" fix flash was performed on your truck. There was an issue re sensor sensitivity and VW had a software fix "disensitize" for it. Good Luck!
rarod58 is offline
post #6 of 6 Old 01-23-2012
don't make this sound like a HACK fix for the problem. This is a EXTREMELY common way to get rid of a fault code in the performance world. I would never ask a shop to put one in. slide under the truck unscrew your rear O2, install spacer reinstall O2. No more fault code It is not that difficult.
If your cat is damaged/clogged from having a missfire (which is very likely) for so long you may need to gutt it OR replace it. If I were selling a car I would install a $10 spacer before installing several hundred in replacement converters. Then the next owner will enjoy better mpg and gained power. Or I guess you could get a remap with a emissions delete if there is a tuner that can do that.
somedude is offline
straight pipes in place of cats?for v10 diesel touareg585 Touareg Exterior Mods 11 04-09-2013 09:49 AM
Want to Buy: stock OE secondary cats catalytic converters slideadams Classifieds 5 06-04-2011 06:27 PM
Remove secondary cats on 4.2 V8? Perry01 Touareg Exterior Mods 27 03-06-2011 03:58 PM
removing 2condary cats on V8 Watcher Touareg Exterior Mods 0 12-21-2008 07:02 AM
Are there any powertrain or drivetrain differences between the V10 Treg and Treg 2? AJN334 General Maintenance & Repair 1 11-05-2008 01:02 PM
