Video on RNS 850 - Club Touareg Forums
post #1 of 22 Old 09-28-2011 Thread Starter
swampg8rs's Avatar
Video on RNS 850
I saw in another thread that the RNS 850 should play m4v video files, however I haven't been successful. It will play DVDs just fine, and plays mp3s and m4a's. My m4v are DVD rips converted to m4v using Handbrake with the AppleTV 2 profile, which uses the h.264 codec. Owner's manual (pg 212) says this should work. My bitrates are below 2000 as well.
any thoughts?
swampg8rs is offline
post #2 of 22 Old 10-01-2011
Touareg: 2011 V6 TDI
I've been pulling my hair out trying to use Handbrake to make m4v's that will work. It is very frustrating and I've tried so many settings I have lost track. If I remember correctly, I was able to get it to work when I used the "Universal" setting under the apple drop down. I changed the average bitrate to 1000 and then my videos worked. It did however change the aspect ratio of my movies just slightly, a bit stretched horizontally but not too bad. Give that a try and see if it works.
Robert.
Robert Mac is offline
post #3 of 22 Old 11-26-2011
ASHILee's Avatar
Try to convert the video's to MP4. I had a MP4 file, put it on a SD Card and also saved it on the HDrive in the Treg. Both work fine. Great when I have to wait an hour for the kids to finish their after school programs.
ASHILee is offline
post #4 of 22 Old 11-27-2011
BrewDude's Avatar
Took all the great advice this thread had to offer and low and behold it all worked, most of it anyway.
Instead of being letterboxed or in a 4:3 aspect ratio video is squared off. This is just from one video, but I'll experiment with setting in HB and see if I can get it to work in its original ratio.
BrewDude is offline
post #5 of 22 Old 12-29-2011
matsoutback's Avatar
Brewdude, any luck with the settings on Handbrake to get the aspect ratio right?
I have tried toggling anamorphic on and off, different screen ratios etc, without success. I just get black strips either side of the video when playing around with the width and heights...
- LC200 Sahara -
Unfortunately sold my Touareg MY12 : 4xMotion, Air suspension, sun roof, driver assist, sport interior, Bi-xenon.
matsoutback is offline
post #6 of 22 Old 12-29-2011
BrewDude's Avatar
Haven't had time with the holidays and work schedule to do any tweaking. I'm thinking resolution must be set manually to whatever the screen size it. Saw it on here somewheres...
BrewDude is offline
post #7 of 22 Old 04-09-2012
Shaolo's Avatar
Second Vehicle: 2009 V6 TDI
Any luck getting an m4v to play?
It's listed as compatible in the manual.
Shaolo is offline
post #8 of 22 Old 10-10-2012
Touareg: 2012 V6 FSI
bump?
toughluck is offline
post #9 of 22 Old 10-11-2012
Played with settings of all differents kinds and realized that you need to keep the framerate at < 29.97 fps. Using handbrake profiles doesn't necessarily change the framerate. So make sure however you are converting the files that the framerate is <29.97 fps.
post #10 of 22 Old 11-28-2012
rinaic's Avatar
Second Vehicle: 2004 V8
Send a message via AIM to rinaic Send a message via Skype™ to rinaic
Bump.
I'm also working through this encoding issue.
None my videos played initially. I then got one to play with the Universal settings, but the next two encoded with the same settings didn't work.
I looked and the video that is working is a 29fps with 3400 bit-rate. I think most of the others I tried last night were <2000 bit-rate (spec in the manual) but with a variable fps.
Changing FPS worries me a little from previous handbrake experience. An issue I've had with changing the framerate fps with Handbrake in the past is a disconnect between the audio and video sync. Another can be some strange effects in action sequences.
I've got the encoder running a variety of different settings today and will see what my results are.
Aspect ratio is a lower priority although if I can get some settings that are consistent, I may look at that as well.
'18 Q7 Prestige Night Black/Nougat | '18 Tiguan SEL Silk Blue/Black
Semi-retired in FL since 2008:
In the family: '14 Touareg TDI Lux Black/Black(brother)
Traded
rinaic is offline
Rns 850 my new 2011 egg 2004-2008-2011 Egg VAG-COM 95 05-25-2015 08:26 PM
Video Input to RNS-850? IOIIOOO Mobile Electronics and In Car Entertainment 6 10-27-2012 08:50 AM
19" Atheos with Nice Michelin Tires $850 Shipped grateful_carl Classifieds Archive 28 08-12-2010 08:11 PM
cheaper video solution with video in motion eggyacid General Maintenance & Repair 12 02-11-2008 06:06 PM
