Updated Sat Nav and lost steering wheel controls - Club Touareg Forums
 4Likes
  • 1 Post By SueSpencer
  • 1 Post By nickyt
  • 1 Post By Steve_L
post #1 of 9 Old 06-07-2018 Thread Starter
Hi Guys,
I have bought a 2006 v10 which has the dvd sat nav fitted but didnt come with the disc, so I went on ebay and ordered a replacement. When the disc came it also came with 2 other discs cambus update step 1 and firmware update step 2 and then the maps disc, so since using all the discs I have now lost use of the volume controls on my steering wheel, the radio station is no longer displayed on the screen in the clocks and the stereo also does not turn off when I turn the ignition on. Does anyone know why this has happened and is there anything I can do to get it back to how it was, I wish I hadnt bothered trying to get the sat nav working because it is rubbish anyway and keeps telling me my car is off road!!
Thanks in advance
Sue
geoffreymash likes this.
SueSpencer is offline
post #2 of 9 Old 06-07-2018
Moderator
Steve_L's Avatar
North West = USA ????
I strongly recommend not to get too involved in updating the SATNAV unless you know what you're doing, have researched sufficiently to be (reasonably) confident in knowing what firmware versions and part numbers/map versions are suitable or applicable to your particular unit.
Purchasing from eBay without any of the aforementioned knowledge is most certainly going to land you in your present predicament.
One of 3 things left for you to do.
1. Wait until someone from your region comes in here, and can offer specialist advice/assistance.
2. Contact a VW Independant workshop and seek assistance from them.
3. Go to the bank, organise a loan/mortgage then go to your dealer and say "help?"
Steve_L is offline
post #3 of 9 Old 06-07-2018
The DVD nav was a in-between model. It can work on both the T1 that used the Canbus 1.6 and the T2 that used the Canbus 2.0 protocol. You have flashed software that updated the Nav to only speak in 2.0 protocol while your vehicle only speaks in 1.6 protocol. Therefore the nav and the car are no longer talking to each other.
Fortunately, others have accidentally flashed the wrong software onto the DVD nav before you and (finally) someone came up with a way to fix it.
https://www.clubtouareg.com/forums/f4...se-153930.html
Once you get the canbus corrected, just leave the the nav map running on the display. The system should keep self correcting and eventually it should start displaying you as driving on the roads instead of driving near the roads. Sometimes it takes a hundred or a few hundred miles. This is a "feature" that crops up on the units when a software flash clears all the memory.
Steve_L likes this.
post #4 of 9 Old 06-07-2018
Moderator
Steve_L's Avatar
Cheers @nickyt
Steve_L is offline
post #5 of 9 Old 06-08-2018 Thread Starter
Thank you for your replies, so from reading through that thread do I now need the 1.6 update? I have checked and it is the 2.0 update I have loaded onto my car. I know I am stupid trying to do it myself wont be doing that again!!!
Thanks again
Sue
Steve_L likes this.
post #6 of 9 Old 06-08-2018
Moderator
Steve_L's Avatar
Not stupid at all...now getting educated and more experienced
SueSpencer likes this.
Steve_L is offline
post #7 of 9 Old 06-08-2018 Thread Starter
Ok guys, the ebay seller has said he will send me the 1.6 cambus update do you know if I upload this disc will it reset everthing? I dont want to make it any worse!!
post #8 of 9 Old 06-08-2018
FYI, this owner is in the UK.
post #9 of 9 Old 06-09-2018
As mentioned in the thread, flashing the canbus 1.6 update should get the steering wheel controls working and the unit turning on and off with the ignition.
You will still be driving off road, but let the nav unit run for a few hundred miles. The nav unit uses the gps info, but it also gets information from the car such as compass direction, steering wheel angles, speed, etc. It takes a while, but the nav will eventually figure it out and suddenly you will be driving on the roads. I have only seen this happen on the dvd nav after an software update.
