Japanese import - Club Touareg Forums
  • 1 Post By rmwanga
post #1 of 9 Old 02-27-2019 Thread Starter
Japanese import
Hi all, I bought an exjapan touareg with an aftermarket panasonic head unit. Problem is when the gps realizes that its not in japan it turns off...I've been told to cover the gps antenna with tin foil... where is it???
Rugsy is offline
post #2 of 9 Old 02-27-2019
That's a new one!!
Do read the buying a used Touareg thread - the link is in my signature - so you know the normal stuff to expect! It will.probably save you money at some stage.
post #3 of 9 Old 02-28-2019
Njord's Avatar
Which Touareg model do you have? How about FM radio? Guess you will have to replace FM antenna. Where are you on the planet? You will probably have a problem to attach the rear licence plate (if in Europe).
Njord is offline
post #4 of 9 Old 02-28-2019 Thread Starter
3.6L V6 FSI 2007 with a panasonic strada. Not worried about FM radio, the while radio shuts down...
Rugsy is offline
post #5 of 9 Old 02-28-2019 Thread Starter
Noobytoogy thank you!
Rugsy is offline
post #6 of 9 Old 02-28-2019
Njord's Avatar
Check under the driver's side fender (if it is original antenna). You will probably have to dismantle fender, washing liquid tank and the headlight.
Gute Fahrt!
Njord is offline
post #7 of 9 Old 02-28-2019 Thread Starter
Oh dear, might be easier to disconnect it behind the stereo itself... I'm in Zimbabwe btw! Thank you all
Rugsy is offline
post #8 of 9 Old 03-01-2019
Touareg: 2007 V8
I have similar model imported a few years ago as well from Japan. Usually they do keep the GPS antennas somewhere on the dashboard, next to the bottom of the windscreen (usually in Japan they swapout the original head unit with a Japanese specific one/Panasonic Strada). Although it does sound like you have a problem with the Double Din head unit itself, so you probably need to swapout/upgrade the whole head unit at some point. Thats what I did on mine and I was able to re-use the already installed aftermarket GPS antenna that came with the Panasonic Strada unit.
Andrew149 likes this.
07 VW Touareg T2 - JDM - V8 with Airsuspension
rmwanga is offline
post #9 of 9 Old 03-02-2019
Mr Treg obviously had an aftermarket radio/nav unit fitted at some stage.
The GPS antenna is still on the dash in the bottom RH corner of the windscreen. The cable and connector are still in the dash.
A rear view camera had been fitted and the cable fed to the radio head behind the trim on the RH side. I am now using the camera with a 7" screen that also has selectable video feed from a camera on the back of my boat.
When the video cable for the was installed, they drilled holes large enough for the connectors to feed through but did not seal them. As a result I would get water into the rear and also the boot lid. Took a while to find the holes.
JimJ is offline
How To Import a Touareg from USA to Canada nickm Canada 63 07-31-2014 08:50 AM
Japanese Pioneer Navi in 2006 non-nav Touareg? dankeff Mobile Electronics and In Car Entertainment 13 02-09-2012 11:49 AM
USA import? vwDavid Canada 2 08-23-2011 02:53 PM
Considering 2006 V8 import - what to look out for? IanR Canada 3 09-09-2007 08:39 PM
