Help, locked out and even the physical key does not open the car. - Club Touareg Forums
post #1 of 13 Old 03-24-2019 Thread Starter
Touareg: 2010 V8
Send a message via Skype™ to piuric
2011 Touareg 7P, 60K miles.
I drove normally to a nearby mall, stopped there 1h and when returning to the car it did not open.
I tried everything, touching the handles, pressing the buttons on the key, trunk, walking around the car, even tried the physical key but it does not unlock.
I went home and brought the spare key, and same issue, batteries ok, 3v.
The red light on the key illuminates but it does not open.
Inside the car when I tried to unlock, the courtesy lights went on.
If neither the physical key opens the car, how can I open it, any ideas?
Thanks in advance.
piuric is offline
post #2 of 13 Old 03-25-2019
Njord's Avatar
Happened to me twice in February. In both cases I left the car in the same parking slot. (Used to park the car near a hospital for ten days). I suspect some equipment was causing an interference. First time I managed to get in after half an hour of desperate attempts to touch the handles and to press the key fob. Second time it was my wife who opened the left rear door. I described her the problem I experienced earlier and nevertheless I parked the car there. Next days I left the car on the other side of the parking.
Njord is offline
post #3 of 13 Old 03-25-2019
Did you get into the car . . . ?
post #4 of 13 Old 03-25-2019 Thread Starter
Touareg: 2010 V8
Hi, I tried everything but I did not managed to open the car.
Car battery is not dead. I was wondering why the emergency key can not open the door.
piuric is offline
post #5 of 13 Old 03-25-2019
Touareg: 2016 V6 FSI
Wow I had the exact opposite happen a few weeks ago. I could not lock the the car at all. Neither remote or the physical key. In my case it was a faulty gearshift lever switch.
suzy1052 is offline
post #6 of 13 Old 03-25-2019
You need to turn it hard enough you think it might break.
Black Grouse is online now
post #7 of 13 Old 03-25-2019 Thread Starter
Touareg: 2010 V8
I manage to open the car with the key fob, not with the emergency/physical key.
The CR2032 batteries on both keys were measuring 2.99V but for some reason I changed to one new with 3.05V and it worked.
Can 0.06V cause this problem?
The physical key I tried hard and turn 90 degrees to either side but it does not open. I believe this physical key only works when the car battery is dead.
piuric is offline
post #8 of 13 Old 03-25-2019
On the T1, the keylock will become stiff and eventually stop working unless you use key lube. It should be done at least once a year and even better, once in the spring and once in the fall, twice a year. It is shocking how hard it is to turn the key when the lock has been ignored. This will apply to the T2 as well.
As for the later T3 and T4, I will leave it to those owners to chime in.
post #9 of 13 Old 03-25-2019
Touareg: 2014 V6 FSI
It's not just a matter of voltage, but amperage (the work the battery can do) as well. I had a NEW button battery start acting whonky two weeks after I put it in. The fob light would work but it would only open the car sporadically. Changed it again, been fine for the last 6 mos.
gryhnd is offline
post #10 of 13 Old 03-25-2019 Thread Starter
Touareg: 2010 V8
Thank you all for the help I believe the safest way is to have with me always a new spare cr2032 and the tools to change it, or at least check battery amperage always...
piuric is offline
