Front Assist Camera help required (I think?) - Club Touareg Forums
post #1 of 1 Old 2 Weeks Ago Thread Starter
Hi,
I am wondering if anyone knows of checks I can do to determine if my Front assist camera is working or not.
The Adaptive CruiseControl (ACC) in my 2013 Touareg has stopped working.
Everytime i start the car i get the message "ACC and Front Assist not available"
I am trying to work out what the cause is.
Module 85 (Front Camera) did have an error previously but it was cleared and has not returned.
Can anyone with the front camera have a look in live data for module 85 for their values for those noted below?
Previous scan errors below.
13 Adaptive Cruise Control
System description: ACC3
Software number: 7P6907561B
Software version: 0340
Hardware number: 7P6907561
Hardware version: H17
Serial number: 00000000000000
ODX name: EV_AdaptCruisContrVW526
ODX version: 002011
Long coding: 3F04010101
Trouble codes:
C110BF0 - Adaptive cruise control sensor Restricted view
Intermittent
U111300 - Function limitation due to received malfunction value
static
5F Information Control Unit
System description: H-BNT-RW
Software number: 7P6035764C
Software version: 0537
Hardware number: 7P6035764
Hardware version: H46
Serial number: 479F+0C7520284
Long coding: 020A01050040C9EF79102B0E00000003F00001030000000000
Subsystems:
System description: ROW 2012
Software number: 8R0060884AJ
Software version: 0403
System description: DU8 SV Touch
Software number: 7P6919603
Software version: 0045
Hardware version: H26
Serial number: VWZ8Z9M7801GXW
System description: CD-Database
Software number: 8R0060961C
Software version: 3638
Trouble codes:
00658 - Operating unit No signal/communication
Intermittent
85 On-Board Camera
System description: DPC-SG
Software number: 7P6907217B
Software version: 0035
Hardware number: 7P6907217
Hardware version: H24
Serial number: 26213002542100000004507461
ODX name: EV_OnBoardCamerDTR
ODX version: 001001
Long coding: E9030000
Subsystems:
System description: NICKRATENSENS
Software number: 7P6.907.658
Software version: 0001
Hardware version: H02
Serial number: 000000003025171_2196
Trouble codes:
C110400 - Camera malfunction
Intermittent
8E Image Processing Electronics
System description: BV-SG
Software number: 7P6907107B
Hardware number: 7P6907107
Hardware version: H30
Serial number: 00500001250612769101260000
ODX name: EV_BTR
ODX version: 002001
Long coding: 0AA09E040000
Trouble codes:
C110702 - Video line for image processing Signal error
static
The two errors that remain are
Module 13 (ACC) U111300 - Function limitation due to received malfunction value - static
Module 8E (Image Processing Electronics) C110702 - Video line for image processing Signal error - static
When i look at the live data for module 85, I see some values that do do look correct,which makes me think this module has a issue, those being:
Camera control module, status = initialising (which did not change from this)
Outside air temperature = -50 deg C ( definitely was not this cold!)
Chassis height - all 4 corners say -127mm, whereas in another module the values are more realistic and vary when the car is moved (I have air suspension).
Any thoughts on what i can check to find the problem?
I did take the car to VW and they said they would need to do full camera and radar calibration to determine what is causing the cruise control to not function
If i replace the camera with another unit could I expect it to work straight away or would it need the full recalibration to get it functioning?
Craig
2012 MY13 V6 TDI 180kW (CRCA), Silver, Air Suspension, Panoramic Roof, Dynaudio, 20" Pikes Peak Rims, Ventilated Seats, Distance Cruise Control, Lane Departure Warning, Blind Spot Monitor + plus maybe some stuff i haven't discovered yet.
CraigTAus is offline
