Error in RNS 850: Start the Diag. tester feature: Main Unit/Version Update - Club Touareg Forums
post #1 of 1 Old 04-25-2019 Thread Starter
Hello,
I wanted to update the firmware and maps.
First, I updated the firmware from the version „HN+_EU_VW_K0821” to „HN+_EU_VW_P0824”. The firmware upgrade was successful.
Then I started updating the maps from the version „ECE_VW_R_6.26.1” to „ECE_VW_R_6.28.2”.
After starting the map update, a message appeared „Start the Diag. tester feature: Main Unit/Version Update” and the update was failed.
Then I have made all of indicated below actions and after every action I checked if the map update is possible:
- I've tried to install the maps in user defined mode (turning on in green menu option „user defined mode”);
- I’ve copied maps to another SD card and made an attempt to reinstall the maps;
- I’ve deleted the navigation database in the green menu (option „Delete database (will need reboot)”;
- I’ve removed the navigation partition in the green menu (option „Delete Nav HDD partition”).
Because all the above actions did not help, then I installed the map version „ECE_VW_R_6.28.2” activator.
After performing the above actions, each time a message appeared during the attempt to update the maps: „Start the Diag. tester feature: Main Unit/Version Update”. Of course, after completing the above actions, navigation and maps have stopped working.
In the absence of ideas for installing the latest maps, I decided to return to the firmware version „HN+_EU_VW_K0821” and to the map version „ECE_VW_R_6.26.1”. But unfortunately when trying to install firmware version „HN+_EU_VW_K0821” and to the map version „ECE_VW_R_6.26.1” message „Start the Diag. tester feature: Main Unit/Version Update” appears too.
Summing up: now I can’t install any version of the firmware and any version of the map, because I always get a message „Start the Diag. tester feature: Main Unit/Version Update”.
Do you have any idea what to do to install any maps in this situation and to remove from appearing the message: „Start the Diag. tester feature: Main Unit/Version Update”?
Mathewb is offline
RNS 850 Firmware update fail, Magnuson-Moss Warranty Act? AirBull Mobile Electronics and In Car Entertainment 45 08-13-2018 06:48 AM
Update of maps for RNS 850 - Dubai rbenaddi Mobile Electronics and In Car Entertainment 0 09-12-2017 04:05 AM
RNS 850 Firmware/software update menu Flipper Dog Mobile Electronics and In Car Entertainment 2 03-11-2016 09:46 PM
RNS 850 update Dalliance Australia & New Zealand 5 11-09-2015 07:31 PM
RNS 850 Next Map Update Woods Mobile Electronics and In Car Entertainment 5 09-13-2015 11:51 PM
