Can High Low Tap Around Front Seats - Club Touareg Forums
post #1 of 20 Old 04-04-2019 Thread Starter
Learner
Singh's Avatar
Second Vehicle: 2015 V8 TDI
Calling on Touareg experts; does anyone know where I can tap into CAN high & low around the drivers or passenger seat? This is for a 7P, T3/T4
Singh is offline
post #2 of 20 Old 04-04-2019
Hi,
The Touareg features several CAN networks. Depending on what you want to connect, you would have to tap onto one or another.
Gabriel
Gabs14Trg is offline
post #3 of 20 Old 04-04-2019
What are you trying to install, and which network do you want?
- OEM air suspension retrofit
- OEM parking heater retrofit
chewblekka is online now
post #4 of 20 Old 04-04-2019 Thread Starter
Learner
Singh's Avatar
Originally Posted by Gabs14Trg View Post
Hi,
Gabriel
Hi, Thanks I realise. And in my simple understanding of Can network I am looking for Can high and low- otherwise coming from Can gateway(located under dashboard) pins 21 & 5.
Any chance this is available under drivers seat?
Singh is offline
post #5 of 20 Old 04-04-2019 Thread Starter
Learner
Singh's Avatar
Hello chewblekka,
Its the Can gateway high and low.
Trying to install a sound actuator- same as what comes in audi sq7.
The actuator module needs to connect to Can gateway, so then i can enable it via vcds and get it to drive the actuator.
Singh is offline
post #6 of 20 Old 04-04-2019
The CAN bus has several different networks: powertrain, comfort 1 and 2, convenience, infotainment, display, etc.
The sound actuator connects to the powertrain network, pin 5 orange/brown (CAN low), ping 21 orange/black (CAN high) at the CAN gateway J533. You can easily identify any CAN network as the two wires (orange brown and orange(colour) ), they will be a twisted pair.
You can find the powertrain CAN bus wires at the transmission control module under the right front seat. Pin 46 CAN High, pin 34 CAN low. When splicing your connections, you MUST take care. do NOT use crimp connectors. Carefully remove some of the sheathing on the existing CAN wires, strip about 1/2" off the end of the sound actuator wires and wrap them tightly around the respective wires. Solder and heat shrink. You do not want any noise on the CAN network, it will effect how it works.
The Following User Says Thank You to chewblekka For This Useful Post:
iSagen (04-06-2019)
post #7 of 20 Old 04-04-2019 Thread Starter
Learner
Singh's Avatar
Gold! How good is this information. You are the top expert, thanks chewblekka!
Yeah I saw the installation documents and it showed how to splice and connect to Can wires, now i know why.
This will save me from routing the wires all the way into dash and the work associated to pry open plastics and put them back- would like to keep it all original.
The tcm under the seat, how best to identify it from other black boxes?
Singh is offline
post #8 of 20 Old 04-05-2019
It's pretty obvious which module it is. Says "Aisin" and "Getrieb" on the sticker, and the PN starts "0C8".
post #9 of 20 Old 04-05-2019 Thread Starter
Learner
Singh's Avatar
When in vancouver next I am shouting you a beer!
Thanks!
Singh is offline
post #10 of 20 Old 04-05-2019
Second Vehicle: 2006 V8
Well done sir
yrktreg is offline
2002 - 2010 Touareg Off Road Quick Reference Sheet TechDr Off-Roading & Towing 10 10-24-2016 03:21 PM
HID headlight alignment - high versus low beam Toiler General Maintenance & Repair 1 08-19-2015 11:11 AM
High low beam question(still learning my touareg) Arthur7980 Mobile Electronics and In Car Entertainment 4 12-27-2014 04:25 PM
High pitched brake squeal from front brakes rigasr Brakes, Steering, Suspension, Wheels and Tires 10 06-14-2013 10:32 PM
Tdi Touareg: Blinking low and high range eurosurplus General Maintenance & Repair 2 01-19-2009 11:17 PM
