Backup Camera Flickering - Club Touareg Forums
post #1 of 5 Old 11-23-2018 Thread Starter
Touareg: 2012 V6 FSI
Question Backup Camera Flickering
Hello
So I Installed an aftermarket backup camera connected it to RCD550 using a video interface
I'm having a problem with getting power for the camera I've already connected it to the backup light wire but It's flickering & I'm having an error for the backup lights on the dash
I just want to know the correct way to supply power for the camera
Thanks in advance
Mohammed A-Naaj is offline
post #2 of 5 Old 11-23-2018
Touareg: 2011 V8 TDI
Maybe taking the power from e.g. cigarrette lighter power outlet in the trunk? Or, if your system needs to wake up automatically, take the power from the same lighter wires and put a relay on the backing light wires.
Juha is offline
post #3 of 5 Old 11-23-2018 Thread Starter
You've just read my mind, this will be my last try if I didn't find another solution
What If I took the 12v from the plate lights & use a relay to disconnect camera when not in reverse?
post #4 of 5 Old 11-23-2018
I would guess that the error message appears when you put more load on the plate lights... Worth a try anyway.
Juha is offline
post #5 of 5 Old 11-23-2018
The reverse lights are probably somehow linked to the can bus and/or the bulb out circuit check is interfering with the signal. Isolate it with a relay and/or use another source with a relay and the problem might go away.
