What does the Touareg have in common with Ferrari? - Club Touareg Forums
  • 1 Post By Odessa
Old 12-28-2018 Thread Starter
etischer's Avatar
It appears the front pads on a Gen 1 & 2 Touareg are the same ones used on...
Ferrari F430
Ferrari 612 Scagiletti
Aston Martin DB9
Aston Martin Vantage
Corvette
Touareg
2014 Touareg Tdi
'03 Range Rover HSE
Home built drive inverter
33kWh Lithium pack
90k electric miles since 2008
etischer is offline
Old 12-28-2018
New2Tregs's Avatar
Just my opinion, but from what I've read about Touareg brake pads... it's best to go with OEM. Aftermarket like EBC will give more bite but also more brake dust. Not a trade off I'm willing to accept as the OEM seem to stop the Treg just fine.
New2Tregs is offline
Old 12-28-2018
Kubelwagen's Avatar
Fancy Italian Brembo six piston calipers to haul the beast down from speed.
Kubelwagen is offline
etischer's Avatar
We tow a travel trailer semi-frequently, so I'm looking for the best stopping power I can get. I had the yellow EBC pads on my Range Rover and finally found a pad I'm happy with. With so many different OEMs supplying parts; so many different auto manufacturers choosing OEMs, and so many friction materials available within each OEM lineup, the chances of finding a pad I'm happy with is pretty slim.
When I'm buying "EBC Yellow" pads, at least I know they will have the same formulation I'm familiar with, no matter what car I have them on (Land Rover, VW, Honda... Lambo)
2014 Touareg Tdi
'03 Range Rover HSE
33kWh Lithium pack
etischer is offline
Old 12-29-2018
Odessa's Avatar
Touareg: 2009 V6 TDI
This advert might appear to be that the vehicles listed in question are of the same "size" diameter etc and rotor size caliper.
I doubt that Ferrari would or Aston have exactly the same although that would be interesting and i also doubt that one would want o buy EBC over brembo, ATE etc etc
Black Grouse likes this.
MY08 - 2009 - TDI V6 (CASA) - APR Tune *** Zenec ZE-NC2051D - Bluetooth - USB - DVD & MZone *** Air Suspension - AFS Xenon - OEM Rear Full Spare - OEM Tow Pack - TPMS. *** Alex G : Light bar, Winch bar - PLUS 8T Winch, Rock-sliders, front & centre under body armour protection, Rear Diff (Flying Nun) and Rear A-Arm armour Protection. *** Car DNA rear lights - Ulter Sport Exhaust Tips - M&H Pro Vent 200 - Team Heko Deflectors.
MY05 - V8 Loved, lost but never forgotten. (Gone)
Odessa is offline
Old 12-29-2018
Njord's Avatar
Ferodo, TRW, Brembo, Zimmermann...etc. Who are Mssrs. EBC? They claim they are leaders in brake market, however not even in the list of substitutes. So, finally, which year the Yellowstaff compatible to? The table quoting 2007-2017? https://www.ebay.com/itm/EBC-DP41908...75.c1#viTabs_0
Njord is offline
Old 12-29-2018
gazaflash's Avatar
I for one would not recommend TRW. It is an inferior pad used on Brembo discs. I was weary about installing these some time ago, but the supplier only had those at the time so I thought I would try it. Not happy. Only thing good was less brake dust! Stopping ability when cold, negative. Stopping when hot, negative. Very little initial bite when cold or warm and felt soft through the pedal. Co-efficient of friction much less. Wore through pretty quickly.
Changed to Pagid pads on Brembo discs and had consistent feel through the pedal came back, high initial bite no mushy pedal when hot. More brake dust, but to me, stopping ability is more important than brake dust.
EBC, Brembo ceramic, Pagid, Hawke or OEM (they squeal!) are very good
Stay away from TRW, Monroe or any USA type brand. Inferior quality
If brake dust is a concern, clean wheels with suitable cleaner and spray Autoglym wheel sealer. It will minimises brake dust adhering to the wheels for a long time. i use it on race and rally car wheels which is very effective.
gazaflash is offline
Old 12-29-2018
gazaflash's Avatar
It doesn’t surprise me that Brembo callipers fit Ferrari, Touareg etc... They like other brake manufactures have various callipers and the designer looks at the specs and specifies accordingly. They are not going to re-invent the wheel for every car that comes along. way too costly. Things the designer would look at, overall size, mount type, offset, heat range, co-efficient of friction, fluid type, materials, etc... and check with ones will fit for their application. Then they would test the calliper, then do infield testing at various climates, temperatures etc...
Brembo seems to be the flavour now as they are a known brand that most people know about and their stock is readily available at a reasonable cost and are used in the racing fraternity.
True racing aficionados tend to go with true and tested AP, Tilton, Willwoood etc...
Old 12-30-2018
Odessa's Avatar
Brembo's are on Kia's these days. They have "out sourced" their product to the market. sooo cant really use Brembo as a starting peg so to speak. Could we ??? I havent and would not. I swear by Ate.!
Odessa is offline
