VCDS height adjustment 2004 air suspension - Club Touareg Forums
post #1 of 16 Old 4 Weeks Ago Thread Starter
KraftwerkTurbo's Avatar
I want to recalibrate my air suspension height settings with VCDS
After entering the corrected values for front left, front right, rear left, rear right, I select "confirm", but 'test' and 'save' don't show up/highlight.
How to 'complete' the revision?
2001 TT225 Quattro, built block, AEB heads, 1000cc, E85, 67mm hybrid K04, clutch, flywheel, suspension, brakes.
2002 Allroad 6spd, built block, 750cc, E85, 30 psi.
2003 RS6 stage 1, coil over. Bigger SMIC. HITCH.
2004 Touareg V8, air suspension, towing.
2005 Golf TDI stage 1, GTI and lowered.
2006 Passat DSG, stage 2
2006 A4 DSG, stage 2, lower, wider.
2009 Jetta 2.5 stock
KraftwerkTurbo is offline
post #2 of 16 Old 4 Weeks Ago
Multiple v10tdi owner
Blownvette's Avatar
Second Vehicle: 2004 V10 TDI
Leave it alone! It can be changed but it’s not worth the problems it can cause. It changes the ride height.
Blownvette is offline
post #3 of 16 Old 4 Weeks Ago Thread Starter
Originally Posted by Blownvette View Post
Leave it alone! It can be changed but itís not worth the problems it can cause. It changes the ride height.
I have been changing ride height (modifying the stock settings) for years on Audi Allroad. "not worth it" is a very subjective statement. "problems it cause": unless the Touareg is different from all the other cars I have dealt with, there are no problems. Maybe with the exception that using extreme values (like I do on my 'power wagon', which I allow to REALLY drop on the lowest level) will increase the wear on your drive axle U CV joints.
post #4 of 16 Old 4 Weeks Ago
Blownvette's Avatar
Sounds like you know what you are doing. Have fun!
post #5 of 16 Old 4 Weeks Ago Thread Starter
The question was: how to complete the revision? Does anybody know?
post #6 of 16 Old 4 Weeks Ago Thread Starter
Yes, I know what I want to do (recalibrate the height system; that is what the feature is for).
The question was: after entering the new values for each corner (test, save), how to finish the sequence.
post #7 of 16 Old 4 Weeks Ago
There is no harm if someone wanted to permanently change the ride height to plus or minus a small amount. I am not sure that the small amount of change is worth it. If you make a large change, then the system will go into an error mode.
If you search the board, most of these threads have turned into Help! I changed the settings and now my car is screwed over.
So nothing harmful is meant by the Don't do it. It's not worth it! It is just trying to keep someone who doesn't understand how easy it is to the the controller into a error loop from making that mistake.
Now, I would love to hear from someone who has been doing it on an allroad for years. What did you do? How did it help? What extra driving enjoyment did it give you?
post #8 of 16 Old 4 Weeks Ago
I lowered my 2004 Allroad, and all 3 of my Touaregs (2004, 2006, 2015). I lowered each about an inch or so. My 2015 is lowered about 1.5" and looks great with spacers and when in load height. No issues with any of the 4.
- OEM air suspension retrofit
- OEM parking heater retrofit
chewblekka is offline
post #9 of 16 Old 4 Weeks Ago Thread Starter
Back to my original question/problem:
I go through channel 1-4 to test/save/confirm the values.
I am used to going to channel 5, enter "1" test, save, confirm. Then close, log out.
This does NOT work for me on this car, not sure why. when going to channel 5, fields are filled with red 'error' text.
I am still getting error code "adaption not completed"
I also tried using the pull down menu for 'step 5' ("confirm settings"), same effect (fields filled with red 'error' text).
post #10 of 16 Old 3 Weeks Ago
mckpat03's Avatar
This isn't going to be helpful or answer any questions because it's a simple anecdote, so my apologies ahead of time. When I lifted mine, I just followed the instructions on the Ross-Tech website (which is what your'e describing with channels 1-4 and test/save/etc) and it more or less worked out as described. I think I had a few hiccups where things didn't work exactly as instructed the first time, but I went through it two or three times and kept remeasuring just to be sure and everything ended up as I had intended which was a Touareg that was lifted 38mm over stock at all four corners.
Hopefully some of the other knowledgeable air-ride/VCDS guys can chime in. I am totally out of my element with VCDS, honestly; I just stumble around and hope I don't brick the ECU lol.
And for everyone else. Changing the ride height is not a big deal. Quit trying to scare people. Why are you so afraid of modifying a vehicle? We're on a forum that's got a pretty rich history of customization.
- Pat
'15 Jetta TDI - Deleted/tuned hypermiler
mckpat03 is offline
