This is after my 5th alignment. - Club Touareg Forums
post #1 of 9 Old 07-10-2018 Thread Starter
clickscrazy's Avatar
Still pulls right, now steering is off center when driving straight slightly.
At an absolute total loss. (See Photos)
clickscrazy is offline
post #2 of 9 Old 07-10-2018 Thread Starter
The alignment photos:
ID:	216665   Click image for larger version
post #3 of 9 Old 07-10-2018
Runz12s's Avatar
Touareg: 2012 V6 FSI
Those specs are spot on! I had the same problem, after pissing away like $400 at the dealer on alignments I gave up. Took it to my buddy’s shop and found out I had worn out lower control arm bushings. Icing on the cake, I was like 1k out of warranty. The lack luster tech prob didn’t even check the suspension before performing the alignment. Not saying that’s your problem but make sure they center the steering wheel, lock it and give the suspension a good look over.
Runz12s is offline
post #4 of 9 Old 07-11-2018
4ePikanini's Avatar
Touareg: 2005 R5 TDI
Make sure they attach the plates to the wheels properly. If the plates arent square with wheels the readings show square but wheels arent. Its a common fault.
Sent from my S60 using Tapatalk
2001 Gen3 Di-D LWB - SOLD
4ePikanini is offline
post #5 of 9 Old 07-11-2018 Thread Starter
Thank you for the input. It is going to an independent shop on Monday. I will make sure they review the suspension.
It does only have 60k on it. Do you think suspension could still have some failures?
post #6 of 9 Old 07-11-2018
Runz12s's Avatar
Absolutely, my car had 70k when I changed them. I’m at 73 now. Side note changing the control arm bushings solved my steering wheel shake also.
Runz12s is offline
post #7 of 9 Old 07-11-2018
2 ton car. Bound to have some wear.
post #8 of 9 Old 07-11-2018
Touareg: 2004 R5
Originally Posted by Runz12s View Post
The lack luster tech prob didnít even check the suspension before performing the alignment.
That's very unusual. The techs usually check these things before an alignment and won't do the alignment if everything isn't right.
They also check for things that the workshop can get paid to fix.
Flash635 is offline
post #9 of 9 Old 07-11-2018
Runz12s's Avatar
They also check for things that the workshop can get paid to fix.[/QUOTE]
I wish that was true, good techs are getting hard to find here. if you did the normal “shake down” of my front suspension it was all tight. A lot of shops over here do toe and go!
Runz12s is offline
