STOP FAULT RUNNING GEAR - Club Touareg Forums
post #1 of 18 Old 07-28-2018 Thread Starter
Second Vehicle: 2005 V6
Was driving home tonight and noticed that I was bouncing down the road, when the STOP FAULT RUNNING GEAR appeared, and I pulled over. I turned the vehicle off, then let it sit, then restarted and continued to drive and everything seemed OK, then the error came up again, and when I got home a few minutes later, I noticed the rear of my car was LOW. I did a VAGCOM and P0100 and 01772 came up. Should I not drive my vehicle? Not sure what to do and worried that the cost to fix will be $$$$$.
Extreme21 is offline
post #2 of 18 Old 07-29-2018
mtnride's Avatar
Touareg: 2007 V8
Second Vehicle: 2007 V8
P0100 is a MAF fault, try cleaning w/ MAF cleaner first, check wiring and connection or replace MAF.
01772 is a level control fault, first check to see if you are leaking air and use some bubbles fluid that you get for kids to blow bubbles. If you can't find any leaks it could be a bad control module (J197) or a bad level control pressure sensor (G291) or the wiring between the two.
Hope this helps
mtnride is offline
post #3 of 18 Old 07-29-2018
Go into your air suspension module and pull the module faults, too. Post your scan results here if you can.
But X2 on the soapy water. Dilute some regular dish soap and start spraying it on your air lines and the air suspension struts themselves. Also remove the plastic cover underneath the vehicle on the USA passenger side and spray the valve block where all the lines come together (right next to and connected to the air compressor).
Sounds like something is leaking since only the rear end of the car dropped.
The Following User Says Thank You to FSJ Guy For This Useful Post:
lgibson (08-03-2018)
post #4 of 18 Old 07-29-2018
Don't drive the car. It's suspension going out of balance.
post #5 of 18 Old 07-29-2018 Thread Starter
Thanks for the reply. I don't have an Air suspension choice on my VAG, so I am unable to check those codes. I believe you are correct that there is a leak in the rear because the front is fine. I just hope that it is a quick and inexpensive fix.
post #6 of 18 Old 07-29-2018
NatPotter's Avatar
HOLD UP. This can be much easier.
Mine did the EXACT same thing and it's quite simple.
On your upper control arms, you'll see your level sensors for the EAS and headlights. This is a cheaply made butterfly clip held component that falls down. So what likely happened is: One fell down and your car thinks a wheel is hanging underneath the body somewhere(the car doesn't have logical reasoning).
The roadside fix is to ziptie the sensor to the arm. You want to avoid unplugging it because that can be the host of a dealer trip on a flatbed to re-calibrate your suspension.
The sensor is on a pinky-size plastic arm and is on the rear side of the upper control arm in a small hole. Jack your car up, use jack stands, and you'll be able to stuff your head in there and see it. I'm going to look for pictures to aid in my description. *Standby
65laws likes this.
2005 Colorado Red V8 w/ Air, Tow, and severe button whitening. I love it already.
Needs a little TLC but what doesn't?
NatPotter is offline
The Following User Says Thank You to NatPotter For This Useful Post:
Extreme21 (07-29-2018)
post #7 of 18 Old 07-29-2018 Thread Starter
Thanks, Pictures would help!! My neighbor has a lift so hopefully we can get it up and hope for the best.
post #8 of 18 Old 07-29-2018
NatPotter's Avatar
OK, I found a thread on CT. This guy did a good job at explaining how this works and mentions some additional caution that I forgot about.
https://www.clubtouareg.com/forums/f...nge-56907.html
I felt like a total pro after I had this happen on the other side on my way to work. I pulled off the freeway, found a parking lot, grabbed my zip-ties out of the glovebox and as long as there was a door open, the car wouldn't lower onto my arms. Made it to work but only 2 minutes early instead of 10.
Keep us posted.
post #9 of 18 Old 07-29-2018
mtnride's Avatar
Touareg: 2007 V8
Is your Vag not VCDS from Ross-Tech?
mtnride is offline
post #10 of 18 Old 07-29-2018
Good catch about the sensor arms! Forgot about those! Hopefully it's a quick and inexpensive fix!
