Steering Locked Car wont start - Club Touareg Forums
post #1 of 4 Old 07-10-2018 Thread Starter
Hi All... Not new to the forum, but could not reset my old ID "strmrdr81".... Anyways, had an issue with my 2008 V8 Treg... Pulled into a parking spot to go food shopping on Friday, came out, loaded up the treg, got in and nothing. The Vehicle will not start. The steering is locked and I can't get it to unlock. There are NO warning lights on the dashboard, fuel gage battery etc wont move.. The battery is fine and fully juiced, the radio and navigation turns on. The touareg outline displays on the MFID... Windows will not roll down from inside buttons (they will roll down from outside with key in door). I tried hooking up a jumper pack to see if that would trigger an unlock, nothing...
Had to flatbed it to the dealer which was a real pain in the ass since I couldn't get it out of neutral. Had to take the console where the shifter is out and use a screw driver to move the orange tab the the right... Why can't this have a normal manual shift lock somewhere?? I had the battery disconnected for 24 hours, reconnected it still nothing, doesn't seem to want to unlock...
I did a quick scan before i left and saw this.....
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
But i get this when looking further
Address 05: Acc/Start Auth.
Cannot be reached
Address 08: Auto HVAC
Cannot be reached
Couple of questions....
1) Does this sound like KESSY or ignition immobilization unit
2) How do you manually unlock the steering column?
Dealer charges 140/hr and of course warranty is long gone
sean kennedy is offline
The Following User Says Thank You to sean kennedy For This Useful Post:
charlesdavid (07-11-2018)
post #2 of 4 Old 07-11-2018
Bump
post #3 of 4 Old 07-11-2018 Thread Starter
Update, put in new battery and was able to start up the car. Did a re-scan w/ ton of fault codes. I'm going to assume my issue is with this fault code "05-Acc/Start Auth. -- Status: Malfunction 0010" What are all the other faults? If i clear all these DTC, will the all true faults reappear on rescan?
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
22-AWD -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
Address 01: Engine Labels:. 079-907-560-BAR.clb
Part No SW: 7L0 907 560 E HW: 7L0 907 560 E
Component: 4.2l V8/4V 0030
Revision: 79H02--- Serial number: VWX3Z0G6686530
Coding: 04210009590F0D60
Shop #: WSC 31414 790 00001
VCID: 3333E35A372CB25FBC5-5184
1 Fault Found:
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0000 0000
Address 02: Auto Trans Labels:
VCID: 55F77DC29C088C6F721-FFFE
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 L HW: 7L0 907 379 L
Component: ESP ALLRAD MK25E1 0303
Revision: 00H53001
Coding: 0004482
VCID: 42DDB69E78C60BD7273-8016
8 Faults Found:
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 160
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Count: 192
Count: 8448
Count: 203
Count: 1024
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 160
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 8192
Count: 8214
Count: 1026
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 160
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 8448
Count: 8194
Count: 1026
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 160
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 8448
Count: 8208
Count: 1026
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 160
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 8448
Count: 8199
Count: 1026
02053 - Control Module for Transfer Case (J646)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 160
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 8448
Count: 8202
Count: 1026
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 160
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Count: 128
Count: 8448
Count: 8207
Count: 1026
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 161
Mileage: 136454 km
Time Indication: 0
Date: 2018.07.10
Time: 00:00:55
Freeze Frame:
Count: 192
Count: 12545
Count: 294
Count: 3
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 B HW: 5WK 485 17
Component: 11 Kessy 6840
Revision: 68406620 Serial number: VWX3Z0G6686530
Coding: 0147688
VCID: 323DE65EC866BB57B73-8066
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
4 Faults Found:
00288 - Steering Column Lock Actuator (N360)
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
009 - Open or Short to Ground - Intermittent
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
00576 - Terminal 15
006 - Short to Plus - Intermittent
Address 08: Auto HVAC Labels: None
Part No: 7L6 907 044 AF
Component: CLIMAtronic 2+2 4331
Coding: 0021030
Shop #: WSC 08380 444 999999
VCID: 78A914766E9A9107497-802C
Subsystem 1 - Part No: 7L6 907 049 F
Component: CLIMAtronic FOND 0503
1 Fault Found:
010 - Open or Short to Plus
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0 959 655
Component: J234 3A VW8T 0250
Revision: 92011025 Serial number: 0039P003F2R+
Coding: 0013121
VCID: 7AAD0E7E509683173F3-802E
Subsystem 1 - Part No: 7L0 959 339 F
Component: BF-Gewichtsens. 007 0010
Subsystem 2 - Serial number: 3NLY8
Subsystem 3 - Serial number: 0001.01.000000700000000000˙
Subsystem 4 - Serial number: 000000˙
1 Fault Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 31862 km
Time Indication: 0
Date: 2011.04.11
Time: 09:05:11
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 990 HW: 7L6 920 990
Component: J285 KOMBI-INST. 7520
Revision: KHH06V02
Coding: 0007201
VCID: 76B51A4E64CEE7775BB-8022
2 Faults Found:
00438 - Fuel Supply Sensor 2 (G169)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 135976 km
Time Indication: 0
Date: 2018.06.25
Time: 08:38:26
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: 136263 km
Time Indication: 0
Date: 2018.07.02
Time: 10:03:25
Address 22: AWD Labels: None
Part No: 0AD 927 755 BG
Component: TRANSFERCASE 0126
Shop #: WSC 00000 000 00000
VCID: 015F79923D10D0CF7E9-5184
6 Faults Found:
01315 - Transmission Control Module
01316 - ABS Control Module
01336 - Company Data Bus for Comfort System
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 J
Component: LUFTFDR.-CDC- 3C3P1 3125
Coding: 0015521
VCID: 3A2DCE7E101643177F3-806E
4 Faults Found:
00456 - Control Module for Access and Start Control (J51
Part No: 7L6 959 933 A
Component: 19 HSG 0600
Coding: 0000085
VCID: 40D9BC96769A19C7317-4B1E
Subsystem 1 - Part No: 7L0 959 701 P
Component: Tuersteuergeraet FS 6302
Subsystem 2 - Part No: 7L0 959 702 P
Component: Tuersteuergeraet BF 6302
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
4 Faults Found:
00576 - Terminal 15
00928 - Locking Module for Central Locking; Front Driver Side (F220)
01737 - Potentiometer for Mirror Adj. Vertical; Pass. Side
Address 55: Headlight Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 A HW: 7L6 907 357 A
Component: AFS-Steuergeraet 0001
Revision: H02 Serial number:
Coding: 1292419
VCID: 392FD1721510480F769-806C
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X008
Coding: 00000019
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r X008
Coding: 00000019
8 Faults Found:
02236 - Stationary Right Cornering Lamp (Right) (M52)
011 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11101011
Fault Priority: 3
Fault Frequency: 5
Reset counter: 16
Mileage: 128788 km
Time Indication: 0
Date: 2017.11.13
Time: 17:07:00
Freeze Frame:
Voltage: 14.48 V
Speed: 15.6 km/h
ABS 1
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Time Indication: 0
Freeze Frame:
Voltage: 11.79 V
Speed: 0.0 km/h
ABS 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Time Indication: 0
Freeze Frame:
Voltage: 11.79 V
Speed: 0.0 km/h
ABS 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Time Indication: 0
Freeze Frame:
Voltage: 11.79 V
Speed: 0.0 km/h
ABS 0
01324 - Control Module for All Wheel Drive (J492)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 159
Time Indication: 0
Freeze Frame:
Voltage: 11.79 V
Speed: 0.0 km/h
ABS 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Time Indication: 0
Freeze Frame:
Voltage: 11.64 V
Speed: 0.0 km/h
ABS 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Time Indication: 0
Freeze Frame:
Voltage: 11.64 V
Speed: 0.0 km/h
ABS 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Time Indication: 0
Freeze Frame:
Voltage: 11.79 V
Speed: 0.0 km/h
ABS 0
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 L HW: 7L0 907 383 L
Component: J345 Anhaenger 0080
Revision: 4A014001 Serial number: 00000108071879
Coding: 0002050
VCID: 3D27C5620138742F5A1-8068
3 Faults Found:
02579 - Trailer; Left Brake Lamps (M65)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 132
Mileage: 126240 km
Time Indication: 0
Date: 2017.10.31
Time: 16:48:05
02580 - Trailer; Right Brake Lamps (M66)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 132
Mileage: 126240 km
Time Indication: 0
Date: 2017.10.31
Time: 16:48:05
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Mileage: 136454 km
Time Indication: 0
Date: 2018.07.09
Time: 00:00:44
post #4 of 4 Old 07-11-2018
We always suggest, as you have done, doing a scan and recording the results, then clearing the codes, driving the car, rescanning and seeing what, if anything, comes back.
A low battery can throw up all kinds of faults as the Touareg is very sensitive [overly so in my view] to low voltage.
