Squeaking brakes - Club Touareg Forums
post #1 of 8 Old 05-11-2019 Thread Starter
Squeaking brakes
I know thereís many threads on here with issues of squeaking brakes but they all seem to be first thing in the morning or reversing. I could handle that.
Both times Iíve replaced my pads itís squeaked nearly the whole time. Iíve done about 3k miles on new brembo pads and itís still there.
jaykurb is offline
post #2 of 8 Old 05-11-2019
goodmonkey's Avatar
Touareg: 2011 V6 TDI
Is it only when braking lightly, heavily, or all the time when braking? What shape were the discs in or did you replace those as well?
2011 Touareg TDI Executive - 138k miles, 2014 Passat TDI SEL - 88k miles (daily driver)
Previous - 11 other VWs, from A1, A2, G1, B4, B5, A5, A6, NMS platforms. I've owned a few Chevy HDs as well.
VCDS HEX-CAN owner
goodmonkey is offline
post #3 of 8 Old 05-11-2019
Touareg: 2013 V6 FSI
What are you replacing with? Mine never squeak and on the orig brakes at 58k miles.
2013 VW Touareg Exec V6, Black/Black Int, 21" Mallory Wheels.
2015 Audi Q5 2.0T Premium Plus, Black/Black Sport Int
2007 GMC Acadia SLT2, Metallic Brown/Brick Int
Sold:
2013 Buick Enclave Premium, Opel White/Black Int
2006 Mini Cooper S Convertible
2001.5 VW Passat GLX 4Motion
touareg4 is offline
post #4 of 8 Old 05-12-2019
TedC's Avatar
Touareg: 2008 V10 TDI
Second Vehicle: 2008 V10 TDI
Squeaking Brakes
Brush a light smear of hi temp copper grease between the shims and the steel back of the pads, remove the steel shims to accomplish this, also a very light dab of copper hi temp grease on the pad steel ends where they slide and make contact into the calipers. Exercise caution when applying do not get the grease on the friction side of the pads, use a judicious amount. This will fix your problem tc
TedC is offline
The Following User Says Thank You to TedC For This Useful Post:
jaykurb (05-12-2019)
post #5 of 8 Old 05-12-2019 Thread Starter
When the wheels turns it squeaks, sounds like the boots full of crickets if I have the window down. It squeaks constantly doesnít matter if hot or cold, it actually stops squeaking when I brake
jaykurb is offline
post #6 of 8 Old 05-12-2019 Thread Starter
Thanks il give that a try. The person who fitted the pads did say he used copper grease but maybe not in the same way, so wonít hurt trying again.
jaykurb is offline
post #7 of 8 Old 05-12-2019
goodmonkey's Avatar
This symptom can be because the pads are still in contact with the rotors when you aren't applying brake pressure. Typically, that is because the caliper isn't being pushed back, or isn't allowed to go back because the guide pins are gummed up or rusted. It can be overlooked when just putting on new pads, which the application of grease on the back of the clips and pads wouldn't fix a problem with the guide pins. The trick is going to see which one is doing it, because even though it can be loud, it probably is only one brake doing it.
VCDS HEX-CAN owner
The Following User Says Thank You to goodmonkey For This Useful Post:
post #8 of 8 Old 05-13-2019
You might be dragging a brake pad, Do have a lot of brake dust on any or all wheels. My 2012 TDI squeeked on reversing in the morning then went away for the rest of the day,so not the same issue. The new 2016 doesn't squeek at all.
tadpole is offline
Loss of Brakes (Vacuum) Fix, V10 TDI N867LC General Maintenance & Repair 22 03-26-2019 03:54 PM
2010 Touareg Brakes (Maker? & Performance) vfrav8r Brakes, Steering, Suspension, Wheels and Tires 16 09-21-2010 09:25 PM
Change brakes time! Question on choices and rotor sizes iceman Touareg Exterior Mods 4 05-24-2007 12:03 PM
Squeaking Brakes Zippin General Maintenance & Repair 3 05-27-2005 09:55 AM
