Setting Tire Pressure with VCDS - Club Touareg Forums
  • 1 Post By stueveone
post #1 of 1 Old 02-04-2019 Thread Starter
Touareg: 2009 V6 TDI
Hey all,
I just got fitted with some new rubber (Cooper AT3 S4's 265/65-17, which are awesome BTW) and the tire pressure monitoring system was going all nutty, undrstandably, because I am now running 36 psi rather than 39/46. I wanted to adjust the pressure in VCDS down from 46psi/3.2 bar for the 19" wheels that came on the car to 36/2.4bar for the new set up.
Here's what I did:
I went into VAGCOM/module/tire pressure/coding, went to the code helper and hit down a few times to scroll over to the tire pressure front tire byte and then rear tire byte. There is then a drop down menu in bar with various tire pressures listed in increments of .1 bar. Mine was set to 3.2, so I clicked 2.4 (~36psi) and then copy/pasted the new code. The new code was accepted and the tire pressure warning disappeared immediately.
Hope this helps
Best,
Stueve
rwmcm likes this.
stueveone is offline
The Following User Says Thank You to stueveone For This Useful Post:
trdltly (03-23-2019)
2011+ Touareg Steering Wheel Shake - Please only post here jpsjr70 Brakes, Steering, Suspension, Wheels and Tires 1223 01-30-2018 11:33 AM
Tire pressure with upgraded wheels and tires ywang98 Brakes, Steering, Suspension, Wheels and Tires 25 09-05-2017 09:46 AM
Tire Pressure Monitoring System Fault..TPMS is Wonkers! enchanted egg Brakes, Steering, Suspension, Wheels and Tires 44 03-14-2017 10:19 AM
Touareg V6 tire pressure Frank General Maintenance & Repair 4 10-18-2007 08:30 AM
Spike in tire exposes other issues with TPMS.....help GordoG General Maintenance & Repair 1 10-01-2004 09:02 AM
