Red Bling on Callipers but broken bleeder screw - Club Touareg Forums
  • 1 Post By dragline1570
post #1 of 4 Old 09-13-2018 Thread Starter
gazaflash's Avatar
I painted all 4 callipers on the Touareg. Changed the pads, rotors (discs), emergency shoes.
While bleeding the last calliper, the bleeder broke off flush on the housing. What a job getting that out.
All better now.
gazaflash is offline
post #2 of 4 Old 09-14-2018
mine too last week
Ragman likes this.
dragline1570 is offline
post #3 of 4 Old 09-14-2018 Thread Starter
gazaflash's Avatar
What a job getting the broken bleeder out.
Had to remove the newly painted calliper, attempted to remove the broken seized bleeder screw with a tapered screw extractor, didnít work so drilled slightly larger hole, used larger screw extractor, still no joy.
Would have been better with a fluted or spline type stud extractor set but didnít have any)
Started to get concerned as I didnít want to replace the calliper yet!
Drilled the hole out to slightly smaller (0.5mm) than the thread size which is M8 x 1.25 pitch and use a starting tap and slowly start removing the bleeder screw threads bit by bit, I then used a plug tap and further removed swarf and bits from seized bleeder, ground down the edge of a bottoming tap to get all the way to the bottom. Reground a drill bit cutting edge to the same taper ( +2 deg) as the bleeder screw and in a CCW direction, cleaned up the bleeder screw seat.
Used blueing ink on the bleeder screw end and screwed it in. First time, the seat did not show a nice fine edge on the bleeder screw, drilled again, CCW and tried again with the blueing ink. This time, a nice edge consistently all the way round. Torqued the bleeder screw slightly more than normal. Nice and tight with any thread breakdown.
Pressure tested to 1000psi using modified hand pump... Success (phew)
Fitted the calliper back on the Touareg and bled system. Pedal nice and hard and good feeling through the pedal.
ID:	218033   Click image for larger version
post #4 of 4 Old 09-14-2018 Thread Starter
gazaflash's Avatar
more bleeder pics
