No drivers side air shock - Club Touareg Forums
post #1 of 5 Old 04-28-2019 Thread Starter
Just picked up a 05 touareg by. Got it for a really good price because of the air shock issue. After doing a decent amount of reading I know I'm going to have to pick up a vcds from Ross tech or something equivalent to even attempt to work on it.
My symptoms so far: drivers side rear and front do not lift at all. Passenger side seems to work fine. I haven't been able to find a post that has one side not working. Only both front or both rear.
If I try to lower vehicle to lowest setting it always says pressure tank filling.
Besides looking for leaks is there anything else I can check before I get some software to hookup?
Will be looking for leaks tonight and tomorrow, had a late April snowstorm (Canada probles) roll in and kinda wreck my weeknd plans
Jshort12 is offline
post #2 of 5 Old 04-28-2019
If it won't lift one side, but the other side raises/lowers properly, that sounds like a valve block problem, or perhaps height sensors. You need to scan with VCDS and see whats going on.
- OEM air suspension retrofit
- OEM parking heater retrofit
chewblekka is offline
post #3 of 5 Old 04-29-2019
Can't help.on the shock front but do take time to read the buying a used Touareg thread to get up to speed - the link is in my signature.
Also update your profile with model, year and location. It helps others help you.
Click on User CP to do so.
post #4 of 5 Old 04-30-2019 Thread Starter
Yeah I'm going to need to get that vcds soon.
Would most parts from a 04 fit on a 05?
I also noticed a pipe discharging air sometimes under the hood. Is that normal spot for air to come out?
Jshort12 is offline
post #5 of 5 Old 04-30-2019
Yes, all 2003-2009 parts should be compatible, but always verify part numbers first. The air discharge you hear is normal. The system releases any air back through the supply line which is attached to the air cleaner housing.
Wet Drivers Side Floor NYTouaregGirl General Maintenance & Repair 9 04-07-2016 09:24 PM
Driver's Side Front Marker Light BuggytownVW General Maintenance & Repair 5 01-21-2016 09:10 AM
Drivers side front and back foot well wet Laki22 Europe 14 03-01-2015 12:28 PM
Left (Driver's) air box help V8 CrestwoodT1V8 Gasoline Engine, Electric Hybrid and Powertrain | V6, V8, W12, FSI 1 08-28-2013 06:38 AM
Driver's side air bag disabled tjcogan37 General Maintenance & Repair 7 04-10-2004 08:56 AM
