New brakes/flush still spongy??? - Page 3 - Club Touareg Forums
post #21 of 33 Old 06-06-2019 Thread Starter
hayz's Avatar
Replying here as well.
Went to German Autowerks, they're the ones that did my E-brake calibration to get the drums closer. They said bleed looked good to them which was done by Motorkars. Motorkars seemed to be a knowledgeable shop and did the bleed/front pads/rotors but I left them for the brake situation after my specific tech said that TDI's will never have the same brake bite as their Gas counterpart....
Gave Dandinis a call yesterday actually they seem like they could help out in this situation so we will see. Thanks!
hayz is offline
post #22 of 33 Old 06-07-2019 Thread Starter
hayz's Avatar
@TurboABA , do you have SS brake lines on your Treg? If the lines were still in decent shape would SS potentially help?
Also update here: I'm probably getting annoying by this point ha. I went and bed the brakes some more with 60-25mph stops which seemed to help 25% or so....
Went to another shop where the mechanic drives a Q7 and he said my brakes were in the right realm of things. He put my pedal travel down mostly to the way the brakes are and the fact I just put Akebonos on which lack initial bite/grit to them.
So what it looks like is in general this platforms brakes are just a little uninspiring but oem/real performance pads and rotors always help. My plan is to ride out the brakes and when my back brakes are done replace all 4 with the correct brakes/rotors.
My final question to hopefully help with pedal feel for the time being is; are stainless steel braided lines worth it? Has anyone switched to SS when their car was working fine and they received a solid increase in pedal feel?
Also how much should a shop charge to replace lines? (just labor).... I found a pair of Goodridge Touareg specific SS lines for $100 so I would probably got that route even if it gave me marginal improvements.
(might have to start a diff thread for this)
Thanks all
hayz is offline
post #23 of 33 Old 06-08-2019
Negative... Mine is all OEM. It's a pig of an SUV, so I don't expect it to have the same braking performance as my crotch rocket. I'm fine with the way it stops given its size, and I adjust my driving style when towing another pig behind it....
If you already drove other units and they performed the same, it sounds to me like your expectations of the vehicle aren't being met. I'm sure that if you start doing big brake kits and SS lines you'll improve some, but I'm also sure it won't be worth the money you'll be spending.
My suggestion would be to just get different pads that have the bite you're after and sacrifice low dust and life span in the process.
TurboABA is online now
post #24 of 33 Old 4 Weeks Ago
I tried Akebono's on my 04 V8 and did not like the bite. Hard braking on interstate was frightening.
Went back to Pagid and the bite is good...so is the dust.
johnk is online now
post #25 of 33 Old 4 Weeks Ago Thread Starter
hayz's Avatar
Thanks for the replies.
Looks like the conclusion I've come to is that Ceramics on this beast are just not the way to go. The new akebonos on the front didn't help and I'm pretty sure my backs are ceramics too as there is 0 dust.
The plan is to wait it out a bit then go back in for a full brake job front/back with Pagids, TRWs or Textars to make sure I get the bite I need. Once that happens I'll probably double down on the SS lines as well.
hayz is offline
post #26 of 33 Old 4 Weeks Ago
I have a set of Padgid pads for the T3 you can have for free, less than 400 miles on them and just cover the shipping.
The Padgid intial bite is great but they dust a ton, I think the best brake pad for the Touareg driven daily is the OEM pad from VW parts department, it apperas to be a unique pad formula you can only get from VW.
The Padgid pads are ratted GG, the VW pads are FG (see below)
DOT Pad Codes
VWBob is offline
post #27 of 33 Old 4 Weeks Ago
OP, if you are putting track pads on your DD you will need to heat the brakes up before you get optimal performance..... Do a 100-0 stop first to put some heat into them and then see how they bite on initial application.
post #28 of 33 Old 4 Weeks Ago
And that is why I don't put ceramic pads on my daily driver
VWBob is offline
post #29 of 33 Old 4 Weeks Ago
I think others have found ceramics may not be the best choice.
All four sets of pads should be the same make too.
Personally I would check the thickness of the rear rotors and if they are still within service limits then I'd fit a complete NEW set of PAGID pads all round and put up with the dust.
post #30 of 33 Old 4 Weeks Ago Thread Starter
hayz's Avatar
Thanks again all for the replies. Gonna snag some TRW's as many threads praise the bite and price. Once that process starts I'll report back
hayz is offline
bleed , brakes , flush , rotors , spongy
