My 2017 Touareg feels very bumpy - Club Touareg Forums
post #1 of 12 Old 01-22-2019 Thread Starter
Touareg: 2017 V6 FSI
I can feel almost every bump or drop on the road surface when driving at low speed. It's so bad, not only it starts to get my kid motion sickness, I myself sometimes feel sick as the driver.
I used to drive a 12 TDI and it was not like this.
Is there anyway to inspect or adjust the shock absorb?
Thanks!
saltshaker is offline
post #2 of 12 Old 01-22-2019
You can't adjust the suspension.
What size wheels and tires are fitted, what make and model, and what tire pressures are you using?
post #3 of 12 Old 01-22-2019 Thread Starter
It's sport /w tech trim (standard 18' wheel and 255/55 tire) . I filled all 4 tires to 40 PSI
post #4 of 12 Old 01-22-2019
yuyueyuyue's Avatar
Touareg: 2012 Hybrid
Seems like higher than the door sticker's suggestion.
You can visually inspect if the rear shocks are leaking oil
If everything is fine, try carrying some weight in the cargo area, 100lbs on top of each rear suspension, it may help.
2012 Touareg Hybrid
yuyueyuyue is offline
post #5 of 12 Old 01-22-2019
Leaky or blown shocks would soften the bumps.......
Is it "bumpy" or "floaty".......
If you're driving in very cold temps, the shock oil can thicken up and result in a shopping cart type of ride......
My instincts would be worn\blown suspension bushings (you should be able to see uneven wear on tires, and it may even pull or wonder to the sides), or more than likely, crappy tires, or even more than likely, run flats...... although with the size you listed above, I'd be shocked if they were run flats.
post #6 of 12 Old 01-22-2019
Lowering your tire pressures will also smooth things out.....I'm not familiar with the sport\tech trims you mentioned, but if it's got "sport" suspension or "lowering" from factory, you're probably on stiffer springs too.....
post #7 of 12 Old 01-22-2019
And the make and model of tire?
Regardless, what does the door placard say the pressures are for a lightly loaded car? I suspect it's not 40 psi.
post #8 of 12 Old 01-22-2019
yuyueyuyue's Avatar
leaked shocks has no oil to buffer the bouncy steel coil springs... once it starts bouncing, it won't stop.
2012 Touareg Hybrid
post #9 of 12 Old 01-23-2019
Read again..... the OP is saying that he has a "jittery" ride..... almost like a SOLID suspension.
I stand by my comments.... shocks only "smooth out - aka dampen" movement, they don't make it RIGID (which is what I'm interpreting that the OP is saying his ride feels like)
post #10 of 12 Old 01-23-2019
Try 33 front 39 rear, like the manual suggests. Maybe drive less crappy roads. This doesn't drive like an American boat, if that's what you were driving last. It should feel firm.
reg26 likes this.
TurdBurgler is offline
