DIY replace brake booster - Club Touareg Forums
  • 1 Post By KraftwerkTurbo
post #1 of 9 Old 1 Week Ago Thread Starter
KraftwerkTurbo's Avatar
Bought the car with code
17887 - Brake Boost Vacuum System
P1479 - 008 - Mechanical Failure
No power brakes.
But also have 'lean' codes on both banks.
Before I order brake booster, is it possible the code and symptoms (no power brakes, STIFF brakes) by just a vacuum leak to the brake booster?
If so: what are easy/common ways to leak test (I have a 'smoker') the V8? Where is it easy to tap in?
2001 TT225 Quattro, built block, AEB heads, 1000cc, E85, 67mm hybrid K04, clutch, flywheel, suspension, brakes.
2002 Allroad 6spd, built block, 750cc, E85, 30 psi.
2003 RS6 stage 1, coil over. Bigger SMIC. HITCH.
2004 Touareg V8, air suspension, towing.
2005 Golf TDI stage 1, GTI and lowered.
2006 Passat DSG, stage 2
2006 A4 DSG, stage 2, lower, wider.
2009 Jetta 2.5 stock
KraftwerkTurbo is offline
post #2 of 9 Old 1 Week Ago Thread Starter
Also (if replacing the brake booster will be required): Any links to good DIY instructions?
post #3 of 9 Old 1 Week Ago
Built4Sin's Avatar
Are you sure its the brake booster itself and not the vacuum line running to it thats cracked? The vacuum line, is a high failure item due to age and cracks.
https://www.clubtouareg.com/forums/f...t2-262402.html
https://www.clubtouareg.com/forums/f...di-260082.html
https://www.ecstuning.com/Volkswagen...Brake_Booster/ (Don't use ECS, just borrow the part numbers)
| Cayenne TT Sways |
Built4Sin is offline
post #4 of 9 Old 1 Week Ago
Can't help on the brakes but when they're fixed do make sure your timing belt is still "in service" - that's no more than 80,000 miles or that it's less than 5 years old.
If in any doubt the belt, tensioners, water pump and thermostat all need replacing.
If the belt lets go the engine is toast as others have found.
post #5 of 9 Old 1 Week Ago Thread Starter
Will see if I can find ANY indication if timing belt service was done. If not: certainly will do (as on all my 1.8T, 2.7T, 2.0T cars).
post #6 of 9 Old 1 Week Ago Thread Starter
[QUOTE=Built4Sin;2053389]Are you sure its the brake booster itself and not the vacuum line running to it thats cracked? The vacuum line, is a high failure item due to age and cracks. /QUOTE]
That is on the list for today. Want to 'smoke' (leak test) the system prior to ordering part. Have seen lots of vac leaks, but really have NEVER had to replace a brake booster.
Any tips where to connect the smoker/block? No experience on V8. Don't even know yet where lines run.
Ideally, like to take MAF off (needs to be blocked off anyways) and fit my cone adapter in to pressurize the system.
post #7 of 9 Old 1 Week Ago Thread Starter
Tried to smoke the car; removed the hoses from the 2 MAFS. Plugged one (brake cleaner can fit nicely), used my 'cone' in the other. But when pressurizing/smoking, the 'hockey puck' (not sure how it is called on the Treg) PCV thing leaked and I did not immediately see an easy way to remove it and plug the lines.
But in the process of checking lines found that a large vac line with barbed end had pulled out of a hard line that had cracked.
Fixed the crack first by wrapping electrical tape around.
Then slipped a hose clamp over the tape, put some black RTV on the barbed side and assembled, tightened hose clamp and let dry/harden.
Brakes working, no codes.
Built4Sin likes this.
post #8 of 9 Old 1 Week Ago
Vacuum Lines. It is almost always the vacuum lines.
PS: Glad you found the leak.
post #9 of 9 Old 1 Week Ago
Built4Sin's Avatar
Awesome! I had gone around my 04 preventatively putting tiny zip ties around the ends of most of the vac lines I could reasonably reach, to keep the lines lasting longer.
| Cayenne TT Sways |
