check brake pads - which one? - Club Touareg Forums
post #1 of 3 Old 02-03-2019 Thread Starter
my08 t2 3.0v6 has a check brake pad light
it appeared after hitting a unmarked speed bump faster than i'd like
the pads all look fine, so i think its a sensor
However, i've not idea which sensor, a full scan on vcds does not show any errors on abs brakes
is there a way we can find out with vcds which sensor it is?
Or can anyone tell me what to check on a visual inspection?
m.r.davies is offline
post #2 of 3 Old 02-04-2019
The brake sensors are fairly low-tech and robust with nothing much to go wrong. If there is a problem it is most likely to be in the short wire that connect each brake pad to the wiring loom.
First clear the error code and see if the problem recurs. If so, you may need to replace the faulty wire. Rather than messing around trying to find the culprit, it may be easier to replace all the wires.
White 150 KW TDI
murraycod is offline
The Following User Says Thank You to murraycod For This Useful Post:
m.r.davies (02-04-2019)
post #3 of 3 Old 02-04-2019 Thread Starter
I cleared all the DTC error codes using vcds, and the brake warning is still there
I assume I have to individually check each wire to figure out where the issue is? is it something that can be done without removing each wheel?
Metal tab thingy on brake pads? siberianjay Brakes, Steering, Suspension, Wheels and Tires 11 09-10-2015 12:04 PM
Brake pads and rotors replacement Shatl Brakes, Steering, Suspension, Wheels and Tires 5 07-14-2015 01:10 AM
Brake coeficient of friction Depiry Brakes, Steering, Suspension, Wheels and Tires 5 05-19-2012 08:40 AM
Check Brake Pads light is still on jepps_420 Brakes, Steering, Suspension, Wheels and Tires 3 04-07-2008 01:44 PM
