changing front and rear suspension bushings + f/r sway bars from Cayenne turbo - Club Touareg Forums
post #1 of 9 Old 09-10-2018 Thread Starter
nikoloz's Avatar
Arrow changing front and rear suspension bushings + f/r sway bars from Cayenne turbo
hi all touaregers
my T1 has 233K kms on the clock. (had only 150K when i bought it 6 years ago) during these 6 years i only changed 2 front lower control arm hydro bushings and thats it, have done lot of off-roading and made some long trips, as everything have got its time off course few front and rear suspension bushings need changing as the car make terrible Squeaking noise while i get in and out of the car and driving it (its embarrassing)
so few days ago I went to my mechanic in VW dealer in Tbilisi and he checked everything for me, so here is the list
1) front upper control arm bushings 2 on each side
2) 2 front lower inner control arm bushings ( I'v got Porsche Cayenne turbo S with only rubber, not hydro ones)
3) rear suspension control arm bushings 8 total (there are 2 arms on each side that need 4 small bushings, BTW there are 3 different types of bushings needed!!!)
4) also going to do what i wanted to do for a long time and put Porsche Cayenne turbo sway bars front with yellow DOT and rear with green DOT to improve handling of already very good SUV (my T1 is on AIR+rear locking diff and do not want to loose off road capabilitys ) i picked both sway bars for 60$ used, front one is a bit rusty and going to sandblast it in my sandblasting shop and powder coat it to make it like new again.
all the bushings that i bought are LEMFORDER (except the front lower ones that are form porsche dealer)
there are all the part numbers on the boxes so if someone will need them in the future.
also going to put new front Zimmerman rotors and Brembo pads
I've got all parts ready and in few days going to change them all together so any suggestions are greatly appreciated
kind regards, Nikoloz
ID:	217825   Click image for larger version
ID:	217829   Click image for larger version
ID:	217833   Click image for larger version
ID:	217837   Click image for larger version
nikoloz is offline
post #2 of 9 Old 09-10-2018
Should make a huge difference. Please post back with your first impressions.
n8henn is offline
post #3 of 9 Old 09-10-2018
I see a green dot sway bar in the last pic. Be sure to let us know how this all turns out for you.
Posted a little bit of background info, for those who might read the thread in the future.
Originally Posted by Oregon TDI View Post
The green dot bars should be the factory standard for Touareg. The Touareg's handling during a quick maneuver is much more crisp now. No noticeable downside in plain driving in term of harshness.
Originally Posted by hotneutron View Post
VW
Front Bars:
7L0411025H - Brown 38x5, 4mm
7L0411025G - Green 38x5, 4mm
7L0411025E - Yellow 37x5, 2
7L0411025D - Blue
Rear Bar:
7P0511025G - Lilac also 7L0511025B
7P0511025H -Green 25mm
7P0511025J - Yellow 25mm also 7L0511025C
7P0511025K - Blue 23mm also 7P0511025A
Porsche:
Front Bars:
955-343-701-80 2014 TTS/GTS/S/Diesel/Base W/O DYNAMIC CHASSIS CONTROL, W/COMFORT SUSPENSION
955-343-701-70 2014 TTS/GTS/S/Diesel/Base W/O DYNAMIC CHASSIS CONTROL, W/O COMFORT SUSPENSION,
955-343-701-80 = 38mm (brown)
955-343-701-70 = 38mm (green)
955-343-701-60 = 38mm (orange)
955-343-701-50 = 37mm (yellow)
Rear Bars:
958-333-701-01 STABILIZER BAR 2014 TTS/GTS/S/Diesel/Base W/O DYNAMIC CHASSIS CONTROL, 25.0MM-GREEN MARK
958-333-701-20 STABILIZER BAR 2014 TTS/GTS/S/Diesel/Base W/O DYNAMIC CHASSIS CONTROL, 24.6MM-LILAC MARK
My reading is
Dynamic Chassis Control = PASM
Comfort Suspension = Air
So for steel T3, the green/green should match cayenne's setup.
post #4 of 9 Old 09-11-2018 Thread Starter
nikoloz's Avatar
thank you guys
BTW currently my 05 V8 with AIR has white DOT on the front bar and lilac DOT on the rear
nikoloz is offline
post #5 of 9 Old 09-12-2018 Thread Starter
nikoloz's Avatar
Talking one step closer now :)
so as you probably have seen front stabilizer bar from turbo S (yellow DOT) was a bit rusty and in bad shape and i did not want you put it on my car so as promised i sandblasted it and powder coated it in black, it turned out very nice vary happy with the results. here are some photos
ID:	217899   Click image for larger version
ID:	217903   Click image for larger version
nikoloz is offline
post #6 of 9 Old 09-12-2018 Thread Starter
nikoloz's Avatar
Thumbs up after sandblasting
with abrasive blasting it has now the best surface to have powder coat paint on it
ID:	217907   Click image for larger version
ID:	217911   Click image for larger version
nikoloz is offline
post #7 of 9 Old 09-12-2018 Thread Starter
nikoloz's Avatar
after powder coating its shining like new :)
only thing its missing is a YELLOW DOT on it )))
ID:	217915   Click image for larger version
ID:	217919   Click image for larger version
nikoloz is offline
post #8 of 9 Old 09-28-2018 Thread Starter
nikoloz's Avatar
well well well..... have some good and bad news....
good news is that i have everything fixed and done, now everything is fine
let me show what i found but please before you will see the photos watch this video and it explains everything that happened
it all started year and a half ago when i was having fun with my mates, few off road lovers have gathered and we were messing around. while this have happened. the field was covered with grass and i could not see the bump, suddenly very nasty sound and hole car jumped, later that day i visually inspected the car and it seemed fine and was not having issues while driving. after few month is started to make squeaking noise. and now i have seen the reason
ID:	218303   Click image for larger version
ID:	218307   Click image for larger version
nikoloz is offline
post #9 of 9 Old 09-28-2018 Thread Starter
nikoloz's Avatar
ok so in total i have 8 new bushing in the rear and 6 in the front also i have new stabilizer bars swapped + alignment for Cayenne Turbo with air and the result is amazing its the best Touareg can get, ride is so much more flat and handling is sharp and feels amazing im sure new bushings also do effect the ride but anyway its all good now
ID:	218311   Click image for larger version
nikoloz is offline
