Calling chewblekka. Need rear air input. - Club Touareg Forums
post #1 of 36 Old 04-19-2019 Thread Starter
chewblekka
Since you've done the full airstrut retrofit, I'd like to pick your brain on an idea......
If I'm not completely wrong, air springs exist that will just "hopefully" slide over my existing gas struts.
I'm only interested in the rears to allow me to eliminate rear squat when towing. If the OEM air springs can fit the regular gas struts, I'm hoping I can replace my steel springs and have a more crude system (instead of the fully integrated air suspension). I realize that I wouldn't have full adjustability or dampening control like with the real thing..... but I could potentially just drive around with 30psi(or whatever) in the springs during normal use, and then I'd bump them up to 50psi or whatever when I'm towing.
Or do the air struts only slide over the corresponding OEM "air" struts?
post #2 of 36 Old 04-19-2019 Thread Starter
post #3 of 36 Old 04-19-2019
chewblekka
Only fit over air struts
regards
Drag
dragline1570 is offline
post #4 of 36 Old 04-19-2019
I don't think you can fit the OEM springs over non-OEM shocks, they seal onto the shock body. It's possible that I'm wrong, it's happened once before
You could run the complete rear bag assemblies and run a small compressor, but then you'd need to control the damping. No current is full hard, 1800mA is full soft. I suppose you could run a resistor and small rheostat somewhere so you could control on the fly.
- OEM air suspension retrofit
- OEM parking heater retrofit
chewblekka is offline
post #5 of 36 Old 04-20-2019 Thread Starter
Is full hard silly stiff compared to the steel springs? You had stiffer than me steel springs since you started off with an Rline if I recall... Do you see massive difference? I will have to entertain the idea of running just the rear air shock as a complete unit I guess. There are all sorts of options in terms of small compressors and related controls (even wireless) but it's starting to sound like I wouldn't end up much cheaper butchering 1/2 truck this way and having a 1/2 ziptied solution vs doing a full blown retro like you and having everything working as it should be...... Crap. Rear air struts would work so much better than these BS WD hitches.
post #6 of 36 Old 04-20-2019
Full hard is like no shock movement at all. Very stiff.
post #7 of 36 Old 04-20-2019
Second Vehicle: 2006 V8
This is always an option, I was looking into this when I was thinking about using an adruino or something similar to control it.
Decided just to do the entire AS swap like Chewy.
Scored some Cayenne rears on E-Bay with less than 10k miles, and a brand new set of Bilstein B4 fronts again on E-Bay for 1/2 price.
The changed how to dynamic dampening works on the shocks/ struts. and luckily it's linear this time. The first revision was a mess. It all current controlled, so it's a PITA to control.
yrktreg is offline
post #8 of 36 Old 04-20-2019
post #9 of 36 Old 04-20-2019 Thread Starter
Thanks for the info boyz.... looks like I'll have to do some shopping to see what I can grab. This seems like a viable solution to address the squat.
post #10 of 36 Old 04-20-2019
Touareg: 2004 R5
Universal Air carries OEM type bags as well as custom designs
I've seen bags that go inside the standard springs with a hole down the middle for the strut..
I've seen them with 1, 2 and 3 bags for various lift sizes.
Flash635 is offline
For Sale: 2008 Touareg T2 V8 - 70K miles, Warranty, Air, Lux, Tech, Rear Locker, Hitch - $1350 EggyV8HybridV6 Classifieds 10 11-14-2017 01:36 PM
why more air in rear tires ron717 General Maintenance & Repair 60 05-02-2010 11:41 AM
Volkswagen : Touareg 2 VR6 NAVI NAVIGATION, REAR CAM, LXRY / AIR SUSP PKG, REAR HTD S eBay Watch Volkswagen Touaregs 0 06-05-2009 03:21 PM
Air suspension not lowering on rear right perbauer General Maintenance & Repair 5 03-04-2008 03:09 PM
